Old 02-11-2009, 12:30 PM
buzzedit buzzedit is offline
Default Another odd PT 8.0 & Rewire/Reason Midi issue
Ok, my writing partner & I were working on a jingle last night and encountered a weird issue while trying to use the acoustic bass combi in Reason. I've searched the forum but not seen this exact error. First, here are the vitals ..
Intel iMac (Penryn) 2.6 ghz with 2 mb Ram
Leopard 10.5.5
Reason 3.05
Midisport 2x2 controller with latest drivers (updated in Dec 08)
Mbox Mini
I added the rewire on insert 1 of a mono instrument track ... reason popped up, set the out to Left 1 in the rewire interface, regular stereo out 1-2 in the mix window. I started recording the midi into the intstrument track, could hear the bass perfectly, all the midi data appeared in the track, but when I tried to playback, nothing ... no sound of any kind, and no action in the track meter. I tried for a while, but no dice. As an expirement, I took the reason out of insert 1 and plugged in a Vaccuum bass ... when I played it back I heard it come through, although it sounded bad ... upon closer look in the midi window, I saw that each midi note had doubled and was about a 16th note later than its predecessor ... basically each note was sounding twice! Very odd ... anybody have any ideas why this would be happening & how to fix?
Thanks!
Old 03-03-2009, 11:10 AM
eyrespace eyrespace is offline
Default Re: Another odd PT 8.0 & Rewire/Reason Midi issue
Some have reported instances of double note entry when using M-Audio controllers with multiple zone assignment. Use the search function for more info.
Rewire issue - Midi Input Problem trying to launch Reason bunderson Pro Tools M-Powered (Win) 28 12-27-2016 08:08 AM
Using Reason and Rewire Issue DonaldM Virtual Instruments 0 02-11-2012 09:27 AM
Odd Reason 4 Rewire Issue Darryl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-05-2010 05:08 PM
Protools 6.4 Rewire issue with Reason 4 on WinXP Darkus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-23-2008 09:49 AM
Reason and Live rewire issue clutch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-24-2006 04:39 AM
