Old 05-26-2005, 10:40 AM
charaggy charaggy is offline
Default Reason Adapted and 3.0 midi input issue
Hi there!! I hope you guys can help me out again with another issue I'm having problems with. Everytime when I launch Reason Adapted or Reason 3.0 in a Protools session (using rewire on a stereo aux input) I get the message that the midi input device is used by another application, which in this case is Protools, but since I'm using rewire this shouldn't be a problem right? :-( All help is highly appreciated cuz it's driving me nuts *laughs*
Cheers to all ya DUCers
P.S. I'm using Protools 6.4 on a 002R.
PC WinXP - Intel Core 2 Quad Q9450 4 Gb RAM
Old 05-26-2005, 11:06 AM
DigiTechSupt's Avatar
Default Re: Reason Adapted and 3.0 midi input issue
In Reason Preferences, under 'Control Surfaces and Keyboards' uncheck 'Use with Reason' for any keyboards, midi interfaces or control surfaces listed. This should disable them and allow Pro Tools to launch without posting that error.
Avid Audio Tech Support
Support FAQ
Old 05-26-2005, 11:17 AM
Thanx for the tip Digisupport I'll give it a try and will letcha know if it works
Cheers!!!
Old 06-01-2005, 09:04 AM
Jeron Jeron is offline
DigiTechSupt,
If I disable the midi controller in Reason, does that mean I cannot use the device to control Reason?
Or will Rewire just pass the information along to Reason and allow me to control it through Pro Tools?
Geez I wish I was at home to try this out.
Jeron
Old 06-01-2005, 10:37 AM
If you're using it in ReWire mode with Pro Tools, Pro Tools will pass midi information to Reason via a MIDI track.
Support FAQ
Rewire issue - Midi Input Problem trying to launch Reason bunderson Pro Tools M-Powered (Win) 28 12-27-2016 08:08 AM
Midi input problem with Reason Adapted bandagedhand 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 09-29-2006 12:39 AM
Midi input problem with Reason Adapted bandagedhand Virtual Instruments 3 09-27-2006 08:11 AM
MBox2 / Reason Adapted Midi Input Latency hairysoundman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-15-2006 11:28 AM
reason adapted midi input itai bn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-30-2005 09:40 AM
