Deleting unused audio regions: problem.
i've got LE.
after i've finished chopping up my tracks and consolidating sections and whatnot, i often go to the right playlist, select unused audio, and delete. but in the last month, it only deletes the unwanted sections from my playlist and not from my audio folders. when i look in the audio folders, the little unused and unwanted pieces of audio are still there. so i end up having hundreds of little chops i don't want. and if i want to get rid of them, i have to sort through all of it. i must of clicked a setting or something. i've been using pro tools for a few years, and haven't had this problem until recently. help! |
Re: Deleting unused audio regions: problem.
Go to the audio regions list on the right hand side of the edit window. At the top of the list select audio. In the pull down window choose: select, then unused regions. Then go back to the audio menu and choose: clear selected.
Then the next very important thing is in the dialog box choose either "REMOVE" which deletes them from the session and not the hardrive. OR "DELETE" Which erases them from the hardrive and session forever. What I do is I choose remove from session then do a save session copy in. This will only save the files that are in the session to the new destination. It also helps in case you screw up and accidently delete something from the hardrive.
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1 Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX. |
Also,
if you saved your session "as" another name before, it won't let you delete it, only remove. If you don't need them, delete any of the actual session saved under different names, then you'll be able to delete from hard disk from within the actual session. Otherwise you'll have to do it manually which can be dangerous to delete stuff in use.
"Sorry! I didn't hear you. WHAT DID YOU SAY!" PTLE 5.1.1 Digi001 MacOS9.2.2 Yikes!400MHz |
yes, that's what i've been doing for three years, and i've not had trouble with it until a month ago. but now, i select 'delete' and they disappear in my audio regions list, but in the audio folder itself the unused parts remain, even though the 'audio regions list' gives every indication that they're "completely gone forever."
so, benlef, if i've been recording a song called "new folder," and after two weeks of work i rename the song "untitled," then when i perform my delete method it will no longer actually delete from the audio folder because it's no longer called "new folder"? i hope that's not right. i should be able to change the session name, and not lose the ability to delete unwanted audio. and i generally only keep one session name per session.
In my case I used to save different mixes under different names causing the regions to be used by different sessions. If I get rid of some regions in one session it will only allow me to remove it from the session. Once I get to the final mix, I get rid of all the older sessions, then open the final one and get rid of the unused regions.
It's not a question of renaming the session, it's about having more than one session using the same regions. Hope this makes it a little clearer. But it looks like it has nothing to do with your problem. Ben
try just removing unwanted audio files from your session lets call it (ex.sesion-1) then go to file choose save-session-copy and make sure the enforce mac/pc box is checked also the copy audio files box is checked
rename session lets call it (ex.session-2)once completed close session find and open (ex.sesion-2) to make sure it loads up if all audio files needed are there and the session opens completly delete (ex.session-1) this is what i do to save space hope this helps |
Nervous about deleting unused regions | Brain Digger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-16-2005 12:59 PM |
deleting unused regions | MR808 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-04-2004 01:27 PM |
deleting unused regions | Nad4 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-09-2003 12:56 AM |
Deleting Unused Regions | robertallen1977 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-11-2002 09:15 PM |
Deleting unused regions, but the audio files still are in the session's folder....... | Trash Man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 02-09-2001 07:11 AM |
