Old 04-01-2021, 06:33 AM
nebosphere nebosphere is offline
Default PT Hangs/Freezes at end of bounce, must force quit
Is anyone else having an issue where at the end of bouncing to disk, where the progress bar is all the way at the end, pro tools just stops and sits there, requiring a force-quit? The bounced audio file is actually fully created and usable but it seems Pro Tools can't recover after the procedure somehow.
Buffer setting seems to make no difference. Real time vs Offline seems to make no difference. In some cases it seems to be related to bouncing to mov and only having selected a portion of the video. In those cases if I select the entire video, everything works. In other cases, however, there is no video involved at all. I can't seem to find a common thread. It's entirely possible it's one of my plugins but I've yet to narrow it down as I haven't finished testing there.
Other than this very annoying glitch, this version seems to be running great!
I'm running Catalina, 2018 Intel Mac mini (2TB/64GB RAM), Radeon RX 580 Pro Tools 2021.3, HDX, UAD Octo, Sonnet PCIe TB2 chassis, Radeon RX 580 eGPU in a Sonnet eGFX chassis on separate TB3 bus from audio.
Old 04-01-2021, 07:46 AM
Default Re: PT Hangs/Freezes at end of bounce, must force quit
As an experiment, try committing batches of tracks(maybe 10 at a time) to see if you can pin this down to a certain plugin
Last edited by albee1952; 04-13-2021 at 12:43 PM. Reason: correct my typo. sorry for confusion
Old 04-01-2021, 08:20 AM
Good idea! When you say commute - do you mean import into a new session?
Old 04-12-2021, 01:30 PM
diogomusique diogomusique is offline
I'm having the same issue here
Old 04-12-2021, 08:35 PM
Seems like it might be related somehow to the frame boundary setting in the bounce window and whether you happen to have a bounce selection that is to the frame or something smaller. Still trying to track it down over here.
Old 04-13-2021, 08:09 AM
climber climber is offline
have not seen this one, and I have been bouncing a TON of session files lately of all different complexities and lengths. FWIW I only bounce to WAV format tho.
Al Hospers
bassist, vocal, composer, engineer
https://www.youtube.com/channel/UCCw...ogfR_7Q/videos
PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
Old 04-13-2021, 08:28 AM
JFreak's Avatar
JFreak JFreak is online now
If you even THINK your issue is plugin related, it is not enough to bounce one track or tracks with plugins disabled. PT loads plugins into memory at start so whatever bad plugin you may have is there even if you do not use it.
So you should try moving all plugins to unused folder, then try again. If bounce goes through, you have better educated guess that some plugin caused it. Finding it is not quick as you need to bring the plugins back one vendor at a time, quitting PT between moving plugins and trying to find out when you get the same problem.
Janne
Old 04-13-2021, 12:43 PM
sorry, I meant COMMIT(so when you get to Bounce, the plugin(s) is inactive
JFreak's comments do bring up a valid point, but figuring out if making a plugin inactive is still part of the troubleshooting process. If you disable every plugin and it still hangs, then I would run his suggestion as the very next step(though I suspect that you can probably skip the stock plugins).
Old 04-13-2021, 12:58 PM
JFreak's Avatar
Unless you have hacked PT to not copy stock plugins to the plugins folder, it is easy to just move everything to unused folder and the stock plugins are copied back automatically on next launch.
Janne
Old 04-13-2021, 08:13 PM
Anyone try bouncing with the pad to frame boundary box checked? If my session happens to be crashing after a bounce, unchecking that box usually fixes it. I would never check it manually - seems pro tools leaves it checked if you had previously bounced an mov and then do another bounce as another audio format (in this case wav).
ProTools Quit Grayed out, can only force Quit real_eyes Pro Tools 2018 6 02-26-2019 06:29 AM
Force quit Next Pro Tools | Intro Discussion 1 08-28-2016 05:44 PM
Pro Tools refuses to quit. Have to force quit. SD2 Pro Tools 10 13 01-23-2014 08:21 AM
The following incident with Altiverb will force me Force Quit PT 25ghosts Pro Tools TDM Systems (Mac) 0 03-02-2009 01:30 PM
Pro Tools must force quit to quit losttimestudios Pro Tools TDM Systems (Mac) 3 03-21-2005 09:32 AM
