Old 11-04-2018, 01:07 PM
field3d field3d is offline
Default Protools with Sibelius rewire and midi
Hello I have some questions using Protools. These are my questions:
1.-When using the rewire with Sibelius, it connects and call Sibelius perfectly and when you click play on Protools sounds excellent calling Sibelius. Now I want to Bounce to a disk offline the mp3 and using the rewire at same time. When I go to bounce and export to mp3 the protools crash and never export the mp3. What could be the problem or how you can bounce an mp3 when you are using rewire with Sibelius? Note here I used an AUX track stereo in Protools to use the rewire.
2.-I know like I said above about the rewire. But suppose now I export a midi in Sibelius and that midi I will export to Protools (not using rewire just loading the midi file). That midi has guitar, bass, and drums with hit hats and kick over times, slah notation. When I import in Protools that midi loads very good but what instrument you select in Protools thatbis able to reconfinze the drums with hit hats, etc., I made in Sibelius? I see xpand2 in Protools but what preset? Or what is suggested here?
Old 11-04-2018, 06:49 PM
Default Re: Protools with Sibelius rewire and midi
I solved point 2. The problem is that by any reason the xpand2 didn’t install presets and other things. I uninstalled and reinstalled airs, xpand latest version from my account of avid and nothing. I solved installing over all the latest versions the version 11.3.1 of the air collection and boom suddenly appeared everything inside xpand2 then there it was easy to do.
Then about why crash Protools when bounces files using rewire in Protools and Sibelius?
Using Rewire with Sibelius 8 TZP Pro Tools 11 1 04-29-2016 09:29 PM
Sibelius First don't appear in Protools as Rewire Client Christiansyn Windows 10 03-03-2013 06:32 AM
Sibelius audio not working through Rewire in Protools fallin2rhythm Pro Tools 10 2 11-16-2012 10:44 AM
Sibelius 6 midi files to into Protools problems LungFish MIDI 5 08-03-2010 06:25 AM
Rewire - ProTools and Sibelius - how? GS-DK Pro Tools TDM Systems (Mac) 0 06-23-2009 11:39 PM
