Go Back   Avid Pro Audio Community > Pro Mixing > System 5
  #31
Old 06-27-2017, 04:19 PM
EddieJones's Avatar
Default Re: eMix 6.0.3 Hybrid will not connect to EuconWS 3.3.2
Did you do a clean uninstall of 3.3.2 or whatever that earlier version was. Don't even try with anything other than 3.6.1 WS installer as it wont work (different EUCON) even if it does show up.
Clean EUCON Script
On the SC264, when you say clean install was that after uninstalling eMix and then the Hybrid App. If you back up titles etc. you could then delete the eMix directory. (but you shouldn't need to, all others using this software are connecting OK)
  #32
Old 06-29-2017, 01:54 PM
David S5 Fusion David S5 Fusion is offline
I've done clean install on clean win image both on sc264 and ws side for several times. Are there an EuCon uninstaller available for win pc?
*Notice: I am running a xeon win10 ws with PT11 and Cubase7+ 8.5. None of the DAWs connecting or ws showing up in lower garage.
Have also tried another ws. It still seems for me like the two last shipping EuCon WS installers for windows are developed for MC, and does not work with Hybrid...?
Thanks!
Avid System 5 Fusion Console (Hybrid)
SC264d - SP663 - eMix v6.1.0
Intel Xeon 12core 64GB RAM Win10
Avid HD Madi
SSL Soundscape 128Madi
ProTools 11 - Cubase 8.5
Avid ML530 - AM713 - MA703 - SSL AlphaLink - MC524
Genelec 1038 + D&B Q1 - QSub - D12 mains
TC M6000 MKII - Lexicon 480L
  #33
Old 06-29-2017, 02:19 PM
EddieJones's Avatar
Yes, use the programs and features control panel icon and uninstall from there.
Thanks!
All other v6.1 customers I have spoken to, hybrid connects and works fine so I don't think that's the case.
Can you try this, Open the HybridApp.ini file that is in Hybrid installation folder on the SC264 and add ; in front of the network lines as per this image. Then save it. HybridApp.ini pic. Restart everything and try to connect (making sure you are using the 3.6.1 EUCON)
If that doesn't work you need to change the network port order metrics. To do this find the network adapters in the SC264 Windows Control Panel and right click on the EUCON/Hybrid Ethernet adapter (not S5) and select properties. See image for what to do and change.. Network Metric change image
  #34
Old 06-29-2017, 04:25 PM
Rpro Rpro is offline
Thanks!
Try changing the network adapter on the EuconWS to a static address and change the last octet until the workstation shows up on the on the upper and lower garages.
Windows Pro 10 X64 - Pro Tools 12.8HDX
Windows Pro 10 X64 - Nuendo 10
Windows Pro 10 X64 - Cubase Pro 10
Euphonix System 5, 408's, 401, 402, 403
eMix 6.1.1.20.1, HybridAPP 20.1, EuconWS 3.6.1
  #35
Old 06-29-2017, 04:46 PM
EddieJones's Avatar
To use static addresses more than this needs to be done. You need to make sure the addresses are on the same subnet, you should either give all nodes a static address and remove the Router/DHCP Server or reserve the ones you use in the Router/DHCP Server. You need to make sure the subnet is different to the S5's internal network.
I would first try the two things I described above then if those don't solve the issue you can try the static address route.
If the SC264 and your Workstations are the only things on the EUCON network (recommended) then you can set all of them to a static address. You do this in the IVP4 settings in Windows (see previous image) or the network preferences on Mac. Use something like IP 192.168.100.1 Subnet 255.255.255.0 for the SC264 EUCON port and then IP 192.168.100.2 Subnet 255.255.255.0 for the WS. If you have more Workstation's then carry on the numbering 3, 4, 5 etc.
Edit: Don't use any addresses in the range 192.168.0.x to 192.168.25.x S5 uses some of these.
  #36
Old 06-30-2017, 05:56 PM
Well, I'm very happy to announce my system is now at last 100% functional!
I'm ashamed to tell I had Cubase 6 installed on both WS's tested. It was the previous necessary Steinberg Eucon adapter which took control on EuCon and made it go bananas wether running PT or Cubase
Uninstalled Cubase 6 + Steinberg adapter. EuCon is up running stable and better than ever both with PT11 and Cubase8.5.
Thank you so much for all your help and patience! Fantastic!
Avid HD Madi
Upgrading from Hybrid 1 to Hybrid 3? tuomiopäivä Virtual Instruments 2 01-11-2016 12:01 AM
Emix v6 VCA spill bergj00 System 5 0 10-06-2014 08:23 PM
Emix v5.3 software with Pro Tools 11 support now available H.G. Hollans System 5 0 02-04-2014 08:55 AM
Emix version and changelog putney System 5 4 01-07-2013 08:20 PM
PT 8.0.3 no Hybrid 6figgas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-01-2010 05:28 PM
