Go Back   Avid Pro Audio Community > Pro Mixing > System 5
  #21
Old 08-05-2016, 08:54 AM
EddieJones's Avatar
Default Re: eMix 6.0.3 Hybrid will not connect to EuconWS 3.3.2
If the older version works with no issues then I would stick on that. We will be releasing new S5 software at some point with new EUCON installers so maybe I can call on you to beta test it and we can hopefully sort this.
  #22
Old 08-05-2016, 09:02 AM
David S5 Fusion David S5 Fusion is offline
I'll stick to the previous version until next version. Previous version can not run with the newest DAW's, but I'll live with that.
I'll be happy to test upcoming version 👍
Thanks!
Sent fra min SM-G925F via Tapatalk
Avid System 5 Fusion Console (Hybrid)
SC264d - SP663 - eMix v6.1.0
Intel Xeon 12core 64GB RAM Win10
Avid HD Madi
SSL Soundscape 128Madi
ProTools 11 - Cubase 8.5
Avid ML530 - AM713 - MA703 - SSL AlphaLink - MC524
Genelec 1038 + D&B Q1 - QSub - D12 mains
TC M6000 MKII - Lexicon 480L
  #23
Old 02-26-2017, 05:08 PM
Rpro Rpro is offline
Originally Posted by David S5 Fusion View Post
Hi Eddie,
Still dealing with this problem. Have made all settings over and over. Also done a full system recovery of the SC264 from the recovery cd's. System is still up running on static ip adresses.
Is there any way to confirm I have the right EuconWS app? Version is 3.3.2.52034 Product version 3.3.2.10406722.
Right now I discovered that Hybrid app shows warning: problems loading configuration file ipythonrc.ini.
Thanks!
If you are on a Windows PC go ahead and disable the firewall then try Eucon again. I had an issue recently that windows 10 enabled the firewall after an update which broke Eucon again. Disabling the firewall again resolved the Eucon issue.
Windows Pro 10 X64 - Pro Tools 12.8HDX
Windows Pro 10 X64 - Nuendo 10
Windows Pro 10 X64 - Cubase Pro 10
Euphonix System 5, 408's, 401, 402, 403
eMix 6.1.1.20.1, HybridAPP 20.1, EuconWS 3.6.1
  #24
Old 06-19-2017, 01:44 PM
Hi Eddie,
Still no fix or updates on this? Is eMix about to be discontinued?
Sent fra min SM-G935F via Tapatalk
Avid HD Madi
  #25
Old 06-19-2017, 02:40 PM
EddieJones's Avatar
Hi Eddie,
We will be releasing v6.1.0 later this week. It has new Eucon 4 (matching S6 and EuControl), the latest Dolby RMU API and support for Dolby Atmos for PT EUCON tracks including 10 wide meters, new pan graph and knobset layout.
  #26
Old 06-19-2017, 10:05 PM
Steven1145 Steven1145 is offline
Oooooohhh nice!
Envoyé de mon SM-G935F en utilisant Tapatalk
Steven Ghouti
YELLOW CAB Studios
Paris, France
The studio FB page
  #27
Old 06-20-2017, 11:18 PM
Nice!
Looking forward to it! :)
Thanks!
Avid HD Madi
  #28
Old 06-22-2017, 06:35 PM
Hi Eddie,
eMix v.6.1.0 installed on mixer side running smooth. Eucon is unfortunately no longer possible to run.
On workstation side installed the shipping EuConWS 3.6.1. Now workstation doesn't even show up in lower garage.
Uninstalled EuConWS 3.6.1, installed previous EuConWS 3.3.2 - workstation shows up in lower garage, but will not connect to hybrid.
Uninstalled EuConWS 3.3.2, installed previous EuConWS 3.1.3 - workstation shows up in lower garage and connects to hybrid. Running unstable.
System still on fixed IP adresses as described earlier on.
The shipping "new features" document is the old one for eMix v.6.0.3
Thanks
Avid HD Madi
  #29
Old 06-22-2017, 07:21 PM
EddieJones's Avatar
Did you by any chance have any older Eucon WS running on the same network ? this new 3.6.1 has EUCON 4 in it and it will not play nice if there are any older versions on the network. Please remove all previous versions of EUCON (including S6 and EuControl) from any connected WS.
I included the v6.0.3 What's new for customers upgrading from v5.
  #30
Old 06-27-2017, 03:06 PM
Hi Eddie,
Only one workstation connected to EuCon network. No other instances of EuConWS running on WS side.
Tried clean installing eMix v.6.1.0 on SC264. WS does not show up in lower garage by any chance with last shipping EuConWS software installed.
If rolling back to previous EuConWS version, WS shows up in lower garage but (of course) no connection is made.
Thanks!
Upgrading from Hybrid 1 to Hybrid 3? tuomiopäivä Virtual Instruments 2 01-11-2016 12:01 AM
Emix v6 VCA spill bergj00 System 5 0 10-06-2014 08:23 PM
Emix v5.3 software with Pro Tools 11 support now available H.G. Hollans System 5 0 02-04-2014 08:55 AM
Emix version and changelog putney System 5 4 01-07-2013 08:20 PM
PT 8.0.3 no Hybrid 6figgas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-01-2010 05:28 PM
