Go Back   Avid Pro Audio Community > Pro Mixing > System 5
Old 04-28-2014, 10:44 PM
klaukholm klaukholm is offline
Default Re: MC Pro Power Supply Problem
We tried the external monitor and as it turns out all that was needed was pressing F1 and a subsequent reboot and a renistall of Eucon as it seems to have gotten corrupted.
So far it is back to normal.
Old 04-29-2014, 07:54 AM
aashton aashton is offline
Exactly the same scenario with my machine F1 and a reinstall and we were back up and running - I'm glad it was a relatively simple fix for you in this case.
All the best - Andrew
Old 04-29-2014, 08:41 AM
You were very helpful!
To anyone else having the problem, try just pressing F1 even if all you see is a white screen - it may be that simple!
Old 08-29-2014, 12:24 AM
blob blob is offline
Originally Posted by greco View Post
Hi Andrew,
On my MC, it was the CMOS-backup-battery (sitting on the SBC inside of the MC, a standard coin type CR2032 battery ), that had run empty (after an estimated 5 years of battery life)
So, exchanging this little battery should solve your problems right away and, then, your MC should hopefully boot up properly again...
Best and good luck,
Stefan
Hi
It seem my battery died. Is there a manual how to open the back panel on the MC PRO tot get to the motherboard?. I only see the screws on the bottom side.
Old 08-30-2014, 03:48 AM
Solved. No manual necessary. :)
Control 24 loss of Faders "possible power supply problem"? Kevin101 ICON & C|24 3 07-15-2020 03:10 PM
192 power supply problem bryan.p Pro Tools TDM Systems (Mac) 4 03-15-2011 09:04 AM
OCZ Powerstream 520W Power supply PROBLEM markus44uk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-03-2008 09:06 AM
power supply not the problem??? chainboy ICON & C|24 1 10-05-2006 08:49 AM
power supply problem manjerie ICON & C|24 1 12-13-2002 08:56 AM
