Old 01-15-2014, 04:08 AM
SD2 SD2 is offline
Default Pro Tools refuses to quit. Have to force quit.
Hello all,
I'm experiencing a quite annoying behavior when trying to quit PT (I've seen some post related to this, but none really helped).
It just won't quit and then , in the active applications window, the app' doesn't respond. Only force-quit will do it.
It doesn't happen everytime but quite regularly.
It already happened under 10.3.7 and 10.3.8 hasn't change a thing.
Any idea?
Thanks
Set up : Mac Pro 2,8GHz QUad Core Intel Xeon (2012), 12Gb RAM, MAC OS 10.7.5, PT HD3 V°10.3.8 (192I/O).
Pro Website
Administrator of Brotools, free online tutorials for the french Pro Tools user.
Old 01-15-2014, 04:19 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Pro Tools refuses to quit. Have to force quit.
Originally Posted by SD2 View Post
Hello all,
Any idea?
Thanks
Its usually an out of date or incompatible plugin! you will need to go through your plugins folder and remove any out of date or demo plugins and make sure every one is up to date.
Also go through the troubleshooting thread listed in the bottom of my post>>>
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-15-2014, 08:09 AM
SD2 SD2 is offline
Hello,
Thanks for the prompt reply.
I'll look into this but have tons of plugs....
Just to make sure: when you say "out of date or incompatible", does that refer to plugs that won't open in PT or could it also concerns plugs that actually work in PT (for example the Pluggos that aren't officialy supported anymore but still work)?
Thanks again
Pro Website
Old 01-15-2014, 11:59 AM
Out if date means anything that the plugin vendor has not specifically blessed as working with your Pro Tools (and maybe OS combination). And even if claimed to work they may still have a bug. To save time start by temporarily removing all third party plugins (actually all plugins that are just not standard with PT 10, or even every last plugin except the mixer plugins) from their RTAS/TDM and AAX folders and starting a Pro a Tools and seeing if the problem goes away. If so you can then suspect it is one or more of those removed party plugins causing the problem and spend time hunting down which one.
Old 01-15-2014, 12:03 PM
When you force quit, OS X should create a crash report. In Console.app under "User...." Reports. Copy the entire text of the most recent report from Pro Tools hanging and being killed and paste it into a post here, you may need to paste it across multiple posts to fit.
Old 01-15-2014, 01:33 PM
SD2 SD2 is offline
I'll do that next time I force quit. Thanks.
Pro Website
Old 01-15-2014, 01:53 PM
Why wait, the last reports should all still be there...
Old 01-15-2014, 04:25 PM
bashville bashville is offline
Were you using Rewire in your session? That behavior happened all the time with me using the Rewire version of the old Steinberg Grand. If you're looking for the first one to try isolating, I'd say start with that.
Also various older versions of Vienna Ensemble Pro used to do that. More recent versions were better.
HD Studio, PT2022.6, UA Apollo x6, 2018 MacBook Pro, 32 Gig, Big Sur
Old 01-20-2014, 02:05 AM
SD2 SD2 is offline
That could be a very good lead since I'm actually working on sound editing along with Sound Miner and a rewire instance in my session.
I'll look into that, thanks.
(as for the report, I never had the reflex to save it....)
Pro Website
Old 01-20-2014, 03:20 AM
crizdee's Avatar
User / your name / library / logs... they should still be there and dated etc
Install the latest rewire from the propeller heads site
Chris
Producer, Engineer,
www.ukmastering.com
Pro Tools refuses to quit Richard Kuschel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-12-2010 09:07 PM
The following incident with Altiverb will force me Force Quit PT 25ghosts Pro Tools TDM Systems (Mac) 0 03-02-2009 01:30 PM
Pro Tools 7 will NOT force quit... soundfx Pro Tools TDM Systems (Mac) 2 04-20-2006 03:04 PM
Pro Tools must force quit to quit losttimestudios Pro Tools TDM Systems (Mac) 3 03-21-2005 09:32 AM
why do I have to force quit DAE? theom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 07-03-2002 12:20 AM
