Old 08-13-2012, 03:48 PM
sw0mgt sw0mgt is offline
Default Best (quietest) computer case for audio?
What is the best computer case for audio? That is, quiet and effective cooling.
So far I've found this guy:
SilverStone Fortress Series FT02
http://www.newegg.com/Product/Produc...82E16811163202
It has 3 x 180mm fans. Bigger fans = less noise!
Foam padded to insulate noise.
Any thoughts on a case that solves this familiar problem concerning audio PCs?
Old 08-14-2012, 08:48 PM
mano111 mano111 is offline
Default Re: Best (quietest) computer case for audio?
The FT02 is a fairly quiet case with great cooling. Its odd orientation and cooling is focused on gaming builds with hot video cards, so for these type of systems it is one of the most quiet options. A good yet pricy case.
A few points on quiet rigs:
Component choice has more to do with noise than the case alone.
Audio rigs don't need very hot video cards so try using a passive cooled GPU.
Case and CPU's fan speed/quality affect total system noise more than fan size. A quality 120mm fan running at under 800RPM is considered inaudiable. Most modern motherboards have BIOS that can control fan speeds.
HDD soft mounting reduces low freqency hum.
Case build quality is a huge factor for reducing vibrations.
An excelent PSU (like Seasonic X gold) will reduce possibility of buzz and other electrical noises.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
Anyone using and AcoustiCase Computer Case? powerjoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-22-2005 08:30 AM
What Rackmount computer case are U using? Ross H 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-08-2004 05:22 AM
So you want the quietest pc case? Calvin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 06-14-2004 11:36 PM
The Quietest computer you know of. GtrDude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 11-03-2003 07:27 AM
Rack case for computer redarrow32 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-27-2001 01:52 PM
