Upgrade/Crossgrade
My MacBook Pro just died, so with a new computer I am assuming that PT LE 7 won't run on Lion, correct? If that is indeed the case, can anyone clarify for me whether or not I would be able to upgrade (or crossgrade) from PT LE7? I see LE addressed on AVID's website, but not 7 specifically. Since 7 is, for all intents and purposes, from a bygone era I just want to be sure that it is eligible.
Appreciate the help! |
Re: Upgrade/Crossgrade
I believe you can cross-grade as long as your digidesign interface has not been used for a cross-grade in the past. What interface do you have? The cross-grade should be $399 and you will need an iLok.
Sweetwater's page is a bit easier to navigate compared to Avid's.
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 | | Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 | |
Also, new Macbook Pros are due to be released on June 11th, so try to hold off. Even if you don't want the new ones, the current ones will start being discounted.
11 Upgrade/Crossgrade | Edenofnick | Pro Tools 11 | 3 | 03-05-2014 02:57 AM |
Upgrade and Crossgrade | mark007 | Pro Tools 10 | 2 | 01-04-2013 11:21 AM |
Can I still upgrade/crossgrade from PT8 LE to PT9? | jackmackdaddy | macOS | 0 | 04-16-2012 01:35 PM |
PT Mp What is best?Crossgrade or upgrade? | Blackers | Pro Tools M-Powered (Mac) | 6 | 05-31-2011 09:47 PM |
Upgrade/Crossgrade to V9 | GTBannah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-15-2010 08:24 PM |
