MP3 Volume problems
When converting a pro tools song to MP3 using avids mp3 option, or itunes, volume on the song drops dramatically to the point of not being able to hear details of the song. Master track volume can be pegged as high as it can go with no improvement in volume. When converting to wav or burning to cd volume is as it should be. It is only a problem when converting to MP3. The MP3 option is basically worthless. Can anyone help?
Whats Up? |
Re: MP3 Volume problems
Go to Pro Tools>Setup>I/O>Output Tab and make sure Default Output Bus and Audition Paths is set to 'Main out'. Should be same in bus Tab.
MP3 option works perfectly for me so it's definitely not worthless. I am somewhat confused as to why a bounced Wav file is at different volume than a bounced MP3 file though.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Setting in I/O is as they should be. Except instead of "mainouts" they are set to analog L/R. I became aware of this "volume" problem After converting a tune to MP3 and emailing it to a friend. He complained he could not hear it clearly using headphones on a laptop. When listening on both his laptop and mine via headphones, the volume problem was the same.....With volumes turned up to max on laptops, you could still barely hear the details of the song. Its a real mystery to me as I have used a number of different MP3 conversion options to convert song including Audacity, and ITunes. Avids MP3 pluggin option produces the same result. Of course to get support from Avid will cost me $30. Thought that maybe someone else had expeirenced the same problem.
Forget about 'converting' files for a moment.
Bounce a song in Wav then bounce the same song in MP3 from Pro Tools. Is the volume different on both bounced files? BTW, what interface are you using & what version of Pro Tools? In Pro Tools>Setup>I/O click 'Default' button on both the Input & Output tabs. Then check Default Output Bus and Audition Paths. The output should correspond to the bus you're using for monitoring ie. the Main bus. With this setup you should be bouncing exactly what you're hearing in the session whether in Wav MP3 or any other format.
I am using protools version 8.4. Been using PT for years. Interface is the 003 rack. When I bounce to wav volume is as it should be. When I bounce to MP3 volume is significantly lower. Go figure. The i/o setup is set to default in both input and out put, the Default output bus and the audition paths are set to analog left and right.
strange aux volume problems. need help | musicmixer04 | Pro Tools TDM Systems (Mac) | 2 | 04-28-2011 04:06 PM |
Volume Problems | cswick | Tips & Tricks | 8 | 10-18-2010 09:38 AM |
valid volume problems | jrspoon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-13-2004 05:03 PM |
volume problems | optymusblu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 05-22-2003 06:02 AM |
Volume problems on bounce | PhReaKy D. MoNKeY | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-03-2002 12:37 AM |
