Old 09-07-2011, 02:59 PM
derFunkenstein derFunkenstein is offline
Default Mbox 2 firmware update fails
I have an Mbox 2 (regular, not mini or pro or micro) running firmware version 1.24. I found the firmware update on the Avid site, and when I run it it can check the firmware version and report it back to me. But when I click Update Firmware, it croaks, saying the firmware download failed. I figured the firmware wasn't actually in the utility because it's so tiny.
At any rate, I only have Windows 7 available to me. Is there a way to update the firmware without Windows XP?
Old 09-08-2011, 07:05 AM
Default Re: Mbox 2 firmware update fails
Bueller? Bueller?
Old 09-08-2011, 08:49 AM
SKI's Avatar
SKI SKI is offline
Not sure about with the mBox but with the 002 the firmware update was tied to the version of PT running.
It was not a case of you should be running the newest firmware, it was a case of you should be running the matching firmware.
If the mBox is the same it could be that your version of firmware is correct for the version of PT you are running.
The 002 would prompt you to update the firmware if it was needed.
Were you prompted to update your firmware or did you try it just because you found it was available?
URBAN MUSIC-
(Hip Hop and R&B)
Old 09-08-2011, 08:55 AM
I'm running 8.0.5 with the current drivers and all that. I updated because I saw it was available and I'm affected by the DAT locking bug that the FW update addresses. I didn't know about the firmware update until I ran into the issue this week. According to this document, it's available for all versions of Pro Tools LE that the Mbox 2 supports.
http://akmedia.digidesign.com/suppor...v143_33126.pdf
It's not the end of the world. It was just a DAT deck I got cheap and wanted to monkey around with.
Eleven Rack Expansion Pack Firmware 2.01 Update fails on Mac OS X Lion DigiTechSupt Eleven Rack 0 10-17-2011 05:16 PM
Please, please tell me there's a Mac firmware update for Mbox 2 Pro. The Mink Pro Tools 9 1 10-12-2011 12:43 PM
HD Sync Firmware update fails VibeProductions Pro Tools TDM Systems (Mac) 2 08-25-2010 03:40 PM
Firmware update available for MBox 2? EllenF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-03-2010 10:33 AM
002r fails to update firmware Quaigy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-22-2007 09:44 AM
