Old 08-25-2010, 03:07 PM
VibeProductions VibeProductions is offline
Default HD Sync Firmware update fails
Dear,
After hours of testing I thought it might be better to post my problem here...
I'm currently running a HD3 on Mac OS 10.6.4 with Pro Tools 8.04 installed. I was able to purchase a second hand HD Sync which works properly but it still has the older firmware on it. When I load protools I get the message that I have to load a newer version of the firmware via the DigiTest Utility (V8.03).
So that's what I tried and every time I Begin the Update it keeps saying that it could not establish the connection with the HD Sync. Its also a brand new cable so nothing is wrong on that side too...
The funny thing is that ProTools detects that the wrong firmware is installed but the Digitest Utility cannot even connect...
I hope someone experienced this before or someone might have a possible solution....
Thanks in advance!
Old 08-25-2010, 03:33 PM
mix109 mix109 is offline
Default Re: HD Sync Firmware update fails
You could try to connect the SYNC to the second card and see if the firmware process will
run as it should
Old 08-25-2010, 03:40 PM
Bob Brown's Avatar
Bob Brown Bob Brown is offline
Evergreen Audio Design Group
Make sure DigiTest is set to talk to the SYNC HD rather than the SYNC.
I believe there is a popup menu for this in the update SYNC firmware pane.
Eleven Rack Expansion Pack Firmware 2.01 Update fails on Mac OS X Lion DigiTechSupt Eleven Rack 0 10-17-2011 05:16 PM
Mbox 2 firmware update fails derFunkenstein 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-08-2011 08:55 AM
002r fails to update firmware Quaigy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-22-2007 09:44 AM
7.3 cs1? and Sync I/o firmware update smlworld Pro Tools TDM Systems (Mac) 5 12-30-2006 07:03 PM
Unable to update Sync I/O firmware Samhein Pro Tools TDM Systems (Mac) 1 05-07-2002 09:18 AM
