Re: Soft Keys/Macros for rendering Audio Suite
Code:
tell application "System Events" set frontmost of process "Pro Tools" to true tell process "Pro Tools" try click menu item "Reverse" of menu 1 of menu item "Other" of menu "AudioSuite" of menu bar 1 repeat until exists (1st window whose name is "Audio Suite: Reverse") -- We wait for the AudioSuite "Reverse" plug-in window to open delay 0.1 end repeat on error e number n tell application "Pro Tools" activate display alert e & " (" & n & ")" message "An Error Occurred" buttons ["Cancel"] default button 1 end tell end try -- Add any other AppleScript code here... end tell end tell Last edited by Oliver M; 07-28-2019 at 03:12 AM. Reason: Corrected a typo. |
Thanks very much.
Pro Tools 2023.9 Ventura 13.6 |
I had a typo in my code but it was in a comment section only.
Thanks for the info.
Hey all,
I'm trying to use the same language used above to hit the SEND button in RX7 Connect (swapping out RENDER for SEND doesn't want to work!), and similarly the same thing for "LEARN" on the Ambience Match module. I was hoping I could simply swap out what buttons I wanted to hit, but no dice. Very new to this, and glad to see the previous posts to get me up to speed. Got my Stream Deck mostly filled, just working on AMB Match and Connect! PS- a learning curve for me in menus was that it is very much Cap Sensitive. Wasted a lot of time with that one. |
Hi all!
I was hoping I would be able to alter that script to click the SEND button on my RX Connect Audio Suite (or even the LEARN button on AMB Match) but no such luck - this is how I tried it: activate application "Pro Tools" tell application "System Events" tell process "Pro Tools" tell (1st window whose name contains "Audio Suite") to click button "SEND" -- SEND button end tell end tell I get the following error - text-script:149:168: execution error: System Events got an error: Can't get button "Send" of window 1 of process "Pro Tools" whose name contains "Audio Suite". (-1728) Macro "RX 7 CONNECT" cancelled (while executing Execute AppleScript). (I did play with capitalization for SEND / Send as I found that capitalization does affect the way these scripts read menus, etc). Anyone have any tips on where I can find more info on selecting certain buttons on Audiosuite with this? |
The Accessibility Inspector in Xcode can be used to find the the real name. 1. Download Xcode from the App Store - it's free. 2. Open Xcode and then select the menu item Xcode/Open Developer Tool/Accessibility Inspector. 3. Click the Start Inspection Follows Point button at the top of the Accessibility Inspector window. You can hover the mouse pointer over the buttons to show which is which. 4. Move your mouse pointer over an AudioSuite button. It should turn green. You will see its name in the Accessibility Inspector window under Basic/Title.
Richard, great advice.
For anyone barking down this rabbit hole, the SEND button for RX 7 Connect is actually titled "Analyze". Swapping that into my script worked! Bonus- the LEARN button on Ambience Match is also titled Analyze |
How to Adress Function Keys >F12 from the S6 (Soft Keys) | innenhofstudios | Avid S4/S6 | 3 | 05-08-2019 06:34 AM |
Soft Keys | spoons | Avid S1, S3, Dock and Control App | 13 | 10-21-2016 07:37 AM |
Why no Soft Keys on S3? | jacko | Avid S1, S3, Dock and Control App | 15 | 02-09-2016 07:43 PM |
Soft Key Macros | BobbyDazzler | Artist Series | 2 | 11-04-2012 08:43 AM |
custom "quick keys" or macros | jahhn | Post - Surround - Video | 0 | 01-14-2005 06:26 PM |
