Seperate Region, Command-E trouble
since a few days, I have the problem, that Command-E is not working sometimes..., after opening for example the preferences window, close it, it works again, but just for a time... Anyone an idea..???? Best Chris OS 10.7, PT HD 10.3.4 (TDM)... |
Re: Seperate Region, Command-E trouble
The keyboard focus is turned on ?
Yes...
Commands for zooming (R) and (T) work... Command-F for fades also doesn't work... Also tried with a connected bluetooth keyboard, it's not physical...;-) |
So there is not an issue in ur software setup - that is sharing the hot keys right ?
It looks, as all Command-Shortcuts of ProTools are blocked, WHEN it appears.. Finder Operations like Command-S, -C, -V work fine... When it comes to special PT Commands, I get this behavior... And like I said, just opening the prefs dialog box, closing it, without changes, working again... It doesn't matter, if I'm in the edit window or for example MIDI Editor... same behavior here... |
I'm on 10.3.2 still so idk about 10.3.4 but we all know there is a issue when PT10 starts up that the focus is shifted away from PT to the finder
I would be curious when it happens if the menu bar focus is on PT Other than that I would say - rolling back a version see if the problem goes away
What do you mean...??
There is a known issue with 10.8
when PT is started the app focus is shifted away from PT to the finder So you just click on the PT app and you are back ready to go I am curious when it loses the commands does the menu bar show PT as the in focus app? Probably so if I had to guess but just a check to make sure
Whoops just saw ur running 10.7.x - sorry
So how about backing back down to 10.3.2? Or 10.3.3
I'll let you know... |
seperate region and other functions | s.d. finley | ICON & C|24 | 7 | 11-28-2017 07:46 AM |
HOW DO I CUT AN AUDIO REGION WITHOUT SELECTING "SEPERATE REGION"? | jjmush | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-23-2011 01:15 PM |
Seperate Region Command PT8 takes minutes...! | m4tune | Pro Tools TDM Systems (Mac) | 12 | 01-02-2009 08:23 AM |
Region Seperate(one click) | guitar131 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-19-2008 07:58 AM |
seperate region | U.Koomran | Pro Tools TDM Systems (Mac) | 1 | 08-05-2003 06:13 AM |
