Old 03-23-2017, 05:18 AM
JC101 JC101 is offline
Default Re: DNxHD stupidity (Compressor and Adobe Media Encoder)
Originally Posted by epm View Post
Had this problem as well, but wanted to continue using compressor, since the droplet is so much easier/faster than opening in media encoder.
Not sure the exact version where Apple broke DNX encoding, but 4.1.3 respects the DNX profiles and the latest version does not. I was able to grab the app from an old install and just copy it over and get it working on a newly installed machine.
I'd be happy to share the file, but not sure if it'll work due to App Store DRM.
PM me if you want the file to try.
I have been searching for a solution to this for some time, it has been causing issues when creating test files. Time to go back through the Time Machine backups and see what versions I can find. Luckily I have these going back almost 2 years.
I will also submit a bug report to Apple, you never know they may actually fix it...
Designer of Sync-One2 / Sync-One2 v2
Old 03-24-2017, 10:03 PM
smurfyou smurfyou is offline
FYI for Adobe Media Encoder I just looked at my preset and remembered there is a setting to not generate the XMP file. It's under the metadata settings.
~Will
Old 03-25-2017, 01:42 PM
StefB's Avatar
StefB StefB is offline
Please think of supporting this in idea scale.
http://protools.ideascale.com/a/dtd/...79?submitted=1
Mac 16 Core 7,1 -Os 10.15.7 - 96 gb Ram - Pro Tools 2022.6 Ultimate in 5 suites - MTRX Studio -S6 26-5-D - Sync HD - Video Satelite (Symphony 2022.5, AJA Kona 3g) Pro Protools 2022.6 Vanilla in 21 x Recording and Edit suites. Mac 6,1 Mac Mini, Mac Mini M1, Mac Studio Pro, Mac Studio Max
Mediacomposer 2021.12 on AJA Kona 3g / XT I/O x 3 suites. Multiple Avid S1, S3 & Docks
Old 12-14-2017, 06:19 AM
A quick test of Apple Compressor 4.4 released today looks like this issue could be, finally, fixed.
Old 12-15-2017, 01:19 PM
onosendai onosendai is offline
So what's the word, what is the best and most compatible Compressor Preset?
i7 5820K, 32GB | Windows 10 Pro, PT 2021.10 Ultimate | RME FF802
Old 05-09-2018, 12:20 PM
KingTor KingTor is offline
Originally Posted by tom_lowe View Post
Any reason you're doing it as a QuickTime not an MXF? If you're using QuickTime, it still has to go through the 32-bit QT engine, if you do it as MXF you'll be using the DNxHD CODEC built-in to the CC suite, so it should be even quicker.
I've been having problems with QuickTimes from Adobe for years now. If this works, I'm going to kiss the ground and pretend you walked on it. Well, probably not literally. That's kinda gross.
I swear I've used the same search terms before and never seen this suggestion. Seriously, thank you.
Tor Kingdon, Chief Sound Guy
Hear Kitty Studiostwitterfacebook
HTML code is On
ADC : bug or stupidity on my part? midnightrambler Pro Tools TDM Systems (Mac) 2 09-08-2009 08:47 AM
More of my stupidity here!!!!! dougied 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-10-2008 08:14 PM
mbox with media encoder for streaming??? kristofor lawson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-13-2005 10:32 PM
Dithering question about SmartCode Encoder Encoder poldo Pro Tools TDM Systems (Mac) 4 05-30-2003 06:41 AM
Windows Media Encoder for Mac? davip General Discussion 4 01-12-2002 03:44 PM
