Will a digi 002 control a HD2 system?
Will a digi 002 console control a HD2 system and still be able to track with the inputs/ADAT?
I'm looking to slowly upgrade to a HD2 setup starting with the PCI cards to free up CPU usage, then add the 192i/o etc since I don't have all the $ to get the whole deal. My main issue right now is maxing out CPU usage due to number of plugins, and I don't want to keep bouncing down back and forth every time I decide I need to change something. I've tried doing some research and even searched the HD forum for "002" and found nothing. Thanks in advance!
Sabertooth X79, i7-3930k hex core, 32GB Corsair XMS 1600 DDR3 ram, Samsung 840 128GB system drive, WD Black 1TB audio drive, Toshiba 1TB samples library drive, MSI 560ti-448 Graphics card, Hyper 212 EVO cooler, Win7 x64 pro. |
Re: Will a digi 002 control a HD2 system?
The short answer is no.
A Command8 or C|24 will work with both LE and HD. Possibly a Pro Control Your going to need the HD cards and the HD interface to get HD working. To the best of my knowlage the 002 is not going to provide any funtionality. Your probably better of trading it in or selling it outright.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
I saw a thread about this a couple of years ago.. I believe the eventual answer was no....
Cheers Dave
2.66 Ghz Quad-Core Intel Xeon, OS 10.6.3 HD3 Accel, Control 24, PT 8.1 cs1 |
There's no halfway point between hd and le. You need to buy an HD core and an HD interface to use HD. LE interfaces only work with LE software, HD interfaces only work with HD software.
- John If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound? |
Cool, just got to wait a little longer is all, thanks!!!
I should be able to get around $600 for my tower now w/ the 6GB ram and 2 hard drives. I guess Vienna Ensemble Pro may also be another option for now with my win7-64 machine but I really don't want to use 2 complete computer setups for this. I just want to be able to run everything without having to keep bouncing things down all the time just to make a track inactive so I can do something else. PITA! If a new macpro would allow me NOT to run into this again, cool, but I want to buy something I know won't give me any issues like what I am having, even if it costs more.
Most Intel Macs will smoke your G5, these days. Even my early 2008 Macbook Pro has outdone any generation of G5 I've ever used. The new i7 MBP dances circles around it. 28 tracks might get a little stuffy on a G5, but some of my sessions have that many tracks of just vocals, all with at least 3 plugs... never mind the dozens of other tracks going as well. As great as those G5s were... they are officially archaic as far as modern computing goes. Their resale value is still pretty decent, though. You could easily take a third off the cost of a new Macbook Pro by selling it, or take a considerable chunk off a Mac Pro.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
How do I sync my MBox 2 system to my Digi 001 System | ER-NYC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-05-2009 10:54 AM |
Digi 003 Control Surface Mackie Control Mode | ctmusicman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-23-2008 07:23 PM |
Getting control latch error on digi test with mix system | BGMusic | Pro Tools TDM Systems (Mac) | 3 | 09-08-2008 06:44 PM |
Digi 002 Rack + Control 8 or Digi 002 Full System | YogiBear | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 11-09-2004 09:38 AM |
control surfaces with a digi 001 system | metal god | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 10-09-2001 01:33 PM |
