Old 04-25-2007, 07:18 AM
blkdog7 blkdog7 is offline
Default Loud popping noise while playing/mixing down long sessions
I record a weekly podcast and use Pro Tools to mix down/edit the show. The show can run as long as almost three hours. Usually it's about one hour and forty five minutes.
Anyways, no matter the length of my podcast I have this same problem. While editing the show, and when I hit play, I get this really loud POP sound. It seems to happen randomly and is not part of the recorded audio. I can never recreate the POP sound in the same spot. Pro Tools is adding it in. And, then, when I bounce the show to a file I then get these pop sounds all over my podcast. It's really annoying and my listeners are starting to complain about it. What is causing this??
I have my playback engine set to 2 processors, 75% CPU, 1024 samples (I think, it's the highest setting) and then Level 8 on that bottom setting.
BTW -- This never seems to happen when I record 3 or 4 minute songs. Only when I mix down my podcast.
What is causing this and how can I get rid of it?? HELP!
I have a Macbook Pro 2.0ghz Dual Core and 1GB ram, and the latest version of Pro Tools 7.3.1 with the latest CS updates.
The Kill Screens (indie rocktronica)
Old 04-25-2007, 08:20 AM
DigiTechSupt's Avatar
Default Re: Loud popping noise while playing/mixing down long sessions
First, change that level 8 back to level 2.
Second - what type of drive are you using for recording and playback and how many tracks do you have in your session? My guess is you're wither using the internal drive (a big no-no) or that you're trying to play to many tracks from a single drive (a firewire drive is qualified up to 24 tracks, though YMMV).
Avid Audio Tech Support
Support FAQ
Old 04-25-2007, 10:48 AM
I am using an external firewire Lacie hard drive. The long podcast sessions only have about 3-5 tracks and I get the pops.
And, I have tried level 2 as well and it still happens. Any ideas??
Loud Popping Phil Huber VENUE Live Sound Systems 4 01-04-2012 08:13 AM
Kontakt Player loud loud noise at play stop Sven62 MIDI 3 05-05-2011 01:43 PM
Random loud popping in PT 7.3.1 cs5 KennyDeVries Pro Tools TDM Systems (Mac) 19 10-19-2008 07:22 AM
Loud Noise Playing MIDI (routing to Reason) milet22 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-30-2006 11:55 AM
Digimax96 - Cycled loud popping and clicking Riad 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 18 07-27-2004 05:53 AM
