Old 06-07-2011, 06:02 AM
yjacket2000 yjacket2000 is offline
Default Can't catch a break...
Well, I'm the day before my mix is due to be sent to mastering, and I've got a problem I hope you can help with.
I was told during the first round of mix revisions that some parts were missing (I was not informed about them, and they were still on an external hard drive). So, I hooked up the hard drive via firewire and found the tracks, imported them, and thought that they were imported into the audio files folder. Well, I started having issues like my vocal was jittering something fierce audibly, with no sign of a problem visually. I figured it must be because ProTools is trying to read files off the external drive. So, I closed and reopened the session to find that indeed, audio files were missing and asking if I wanted to automatically relink, etc. I said no. Went to the files, copied them into the audio files folder manually, turned off the firewire drive and closed the session again. I opened the session and it wanted to relink, so this time I said yes, but no luck.
Next I deleted the tracks in the session so that audio was no longer being looked for and imported them fresh into the session. When I hit play I got a bunch of errors, the last being "Assertion in "..\Mdie_TrackPlayer.cpp", line 469." So, I closed that session and opened a previously saved version of the session. I imported the audio there, and I get the same assertion error. I tried hooking the firewire external drive back up, but I get the same error. I don't know what to do (obviously, or I wouldn't be sending out a cry for help), so if you know what to try, please let me know. If you saw my recent post about my computer crashing on this project, you know I've had a ridiculously tough week. I could use some good news. Thanks in advance for your help. Here's my sandra:
SiSoftware Sandra
Computer
Model : System manufacturer P5K
Workgroup : MSHOME
Host Name : ruffmixstudio
User : Ryan Ruff
Processor
Model : Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
Speed : 2.4GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 1 Unit(s)
Type : Quad-Core
Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size
L2 On-board Cache : 2x 4MB, ECC, Synchronous, ATC, 16-way, 64 byte line size, 2 threads sharing
Computer
Mainboard : Asus P5K
BIOS : AMI 0902 12/24/2007
Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 3GB DIMM DDR2 DDR3
Chipset
Model : ASUS P35/G33/G31 Processor to I/O Controller
Front Side Bus Speed : 4x 267MHz (1GHz)
Memory Bus Speed : 2x 401MHz (802MHz)
Memory Module(s)
Memory Module : A-Data DQVE1A16 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-23-6-3)
Memory Module : A-Data DQVE1908 512MB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-23-6-3)
Video System
Video Adapter : NVIDIA GeForce 7300 SE/7200 GS (2 PS3.0, 2 VS3.0 450MHz, 128MB DDR3 2x810MHz, PCIe 1.00 x16)
Storage Devices
Seagate ST3160815AS (160GB, SATA150, 3.5", NCQ, 8MB Cache) : 149GB (E:)
Seagate ST3320620AS (320GB, SATA300, 3.5", NCQ, 16MB Cache) : 298GB (C:)
TSSTcorp CDDVDW SH-S203N (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:)
Logical Storage Devices
Hard Disk (E:) : 149GB (NTFS) @ Seagate ST3160815AS (160GB, SATA150, 3.5", NCQ, 8MB Cache)
Audio Drive (C:) : 298GB (NTFS) @ Seagate ST3320620AS (320GB, SATA300, 3.5", NCQ, 16MB Cache)
Optical Drive (D:) : N/A @ TSSTcorp CDDVDW SH-S203N (SATA150, DVD+-RW, CD-RW, 2MB Cache)
3.5" 1.44MB (A:) : N/A
Peripherals
LPC Hub Controller 1 : ASUS (ICH9) LPC Interface Controller
LPC Legacy Controller 1 : Winbond W83627DHG
Audio Device : ASUS (ICH9) HD Audio Controller
Audio Codec : Realtek Semiconductor 883 High Definition Audio
Serial Port(s) : 1
Disk Controller : ASUS (ICH9) 2 port Serial ATA Storage Controller 1
Disk Controller : ASUS (ICH9) 2 port Serial ATA Storage Controller 2
Disk Controller : ASUS JMB36X PCIE-to-SATAII/IDE RAID Controller
USB Controller 1 : ASUS (ICH9) USB Universal Host Controller
USB Controller 2 : ASUS (ICH9) USB Universal Host Controller
USB Controller 3 : ASUS (ICH9) USB Universal Host Controller
USB Controller 4 : ASUS (ICH9) USB2 Enhanced Host Controller
USB Controller 5 : ASUS (ICH9) USB Universal Host Controller
USB Controller 6 : ASUS (ICH9) USB Universal Host Controller
USB Controller 7 : ASUS (ICH9) USB Universal Host Controller
USB Controller 8 : ASUS (ICH9) USB2 Enhanced Host Controller
FireWire/1394 Controller 1 : ASUS VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller
SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Network Services
Network Adapter : Attansic L1 Gigabit Ethernet 10/100/1000Base-T Controller - Packet Scheduler Miniport
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows XP Home 5.01.2600 (Service Pack 3)
Platform Compliance : x86
Performance Tips
Tip 2546 : Large memory modules should be ECC/Parity.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Ryan Ruff
ruffmixstudio
info@ruffmixstudio.com
www.ruffmixstudio.com
Computer Specs:
Custom built PC
Windows 7 Home 64-bit
6GB RAM, Intel Core 2 Quad Q6600
160GB SATA HD, 320GB SATA HD (both Seagate Baracuda 7200)
500GB Western Digital Black Caviar SATA HD
ProTools 9.0.6 & MBox2 Mini
PT IEP Upgrade Catch 22 DonaldM Virtual Instruments 0 06-06-2012 05:44 PM
Please, help me to catch that sound! Chance16v Eleven Rack 0 06-03-2012 03:16 PM
laptop catch 22 protein 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-14-2007 12:51 PM
MTP Catch 22 Sparks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-06-2005 03:36 PM
Anybody Catch This Thread? Mr_Seven 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 23 04-11-2002 12:54 AM
