Old 05-18-2017, 12:41 PM
zam226 zam226 is offline
Default HEAT not included with Track Commit
I've seen similar threads but nothing that answers my specific problem....
I'm using HEAT in a PT mix and need to commit it to each individual track - I can't seem to get it to print in my tack commits. It seems like it's supposed to print when using it in Pre-insert mode, but it doesn't seem to make a difference using it pre- or post- it's not printing either way.
Any ideas?
Thanks.
Mac Pro (Late 2013) 3.5 Ghz 6-Core Intel Xenon E5 - OSX 10.10.5 - PT|HD 12.7.1
Old 05-19-2017, 01:35 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: HEAT and Track Commit
Hi, welcome to the community.
Interesting finding! I'll ask around...
Janne
Old 05-19-2017, 02:07 AM
Stig Eliassen's Avatar
HEAT has to be pre-insert to be included when you commit. I just did a test for you, and it works here.
You are on HD, right?
Old 05-19-2017, 12:01 PM
Yes on HD. HEAT works when it's active on a track. I've tested it using both Pre and Post and it makes no difference - when the new track is created heat is on by default, and when I turn it off it hadn't been baked into the new audio created by commit.
Old 05-19-2017, 12:29 PM
My apologies, I spoke too soon. I did a quick test, and then straight into a recording session. I made a mistake when A/B-ing the prints (I don't use HEAT in my productions).
You are correct - it doesn't work. I've now tested commiting both offline and in real-time, and the results are the same. I'll try to investigate further.
Thanks.
Old 05-19-2017, 12:37 PM
midnightrambler midnightrambler is offline
Hmm, I just ran a quick test and it doesn't seem to be committing here when using offline bounce either (realtime or offline). HD native vs HDX?
RTD bounce works fine, as you'd expect - ie HEAT fx is bounced when bussing the track to a new track and recorded real-time.
Old 05-19-2017, 01:02 PM
Hmm interesting, thanks for checking. Let me know if you figure anything out!
HEAT license included in PT12HD also working in PT10HD ? tonwurm Pro Tools 12 4 11-14-2015 03:12 AM
Commit Tracks and HEAT Siegfried Meier Pro Tools 12 10 11-13-2015 06:37 PM
Will Heat for HD Native be included in the next version of PT 11? Justin1524 Pro Tools 11 52 07-25-2015 12:37 AM
Are ReVibe and HEAT not included in new HDX purchases? digidesigner Pro Tools HDX & HD Native Systems (Mac) 6 08-15-2012 08:50 AM
