Old 07-05-2010, 05:21 PM
JustGotPaid JustGotPaid is offline
Default 8 LE won't activate
Hi all,
I have PT LE 8 and M-Powered 8 on an 08 iMac. Naturally, the M-Powered uses the iLok. I use the iLok and M-Powered on my MacBook Pro, which is at another location.
Since I don't have the iLok here at the house I opened LE and the program opened fine, I named the session, etc. but I can't click on the tracks and activate the Record function. It doesn't seem like the mouse works on much of anything. It did this once before, only it was just slow but worked. This time it won't activate anything.
I'm just curious if I have both M-Powered and LE on the same machine, would one over-ride the other, causing me to need the iLok? If not, what could be causing the problem here?
Thanks in advance.
JGP
Old 07-05-2010, 08:15 PM
Default Re: 8 LE won't activate
Must be some temporary glitch in the program. The "quit" was grayed ut and I had to do several force quits, re-open, etc. and it finally started working.
But now...Im using an MBox2 and the recording level is WAY too high. I turned down the gain in the window all the way ( - 85?) and turned the control knobs on the MBox2 all the way to 0. It's still peaking so high that the wav form in the edit window is solid from top to bottom.
How do I turn the record level down?
Thanks again.
JustGotPaid
I need help to activate my code please juan Jose pro macOS 3 06-24-2013 05:02 AM
Can't Activate & D/L PT 10 LightWing Pro Tools 10 1 06-15-2013 05:50 AM
The De-activate/re-activate plugins routine nightmare superbask Pro Tools 9 0 03-21-2011 12:51 PM
Can not activate & download... andersf Pro Tools 9 11 11-06-2010 06:15 AM
Can you re-activate Kontakt 2.2.1... Stig Eliassen Virtual Instruments 0 10-03-2007 01:22 PM
