Old 12-31-2000, 01:33 AM
dave_koz dave_koz is offline
Default Deleting waveform
Hi.. Is it wise to delete the unwanted sound in drum tracks ? for example, deleting all the kick and hihat that mic snare pick up in snare track ? also deleting snare, etc on kick tracks ?
Thanks,
D
Old 12-31-2000, 10:29 AM
QuikDraw QuikDraw is offline
Default Re: Deleting waveform
I think what you'll end up with if you do that is a very unnatural sounding drum track. All of the drum mics pick up the sound of drums other than which they are focused. If you delete the sound in between the actual sounds that you want, you'll end up with a "pumping" type sound, similar to what you'd get with extreme compression. But probably worse. It makes the cymbals especially bad.
That's not to say that it couldn't be used for special effect. Any technique can be useful for something.
What you're describing would be similar to using MIDI drums. That's one reason that MIDI drums don't sound as good as real ones. There's no mix. Each drum sound is in its own isolated test tube. Most MIDI drums are real drums that have been sampled and cleaned up anyway.
Just use mic placement to minimize bleed, or take advantage of it.
There is one song I was working on where the drummer did a rim-shot that was way too weak. I didn't want to make him come back just to fix one weak verse, so I fixed it with editing. I found one particularly good sounding rim-shot hit that didn't have too much other noise, especially cymbals, and pasted a copy of it over all the weak hits (on a new track). The silence in between the hits sounded awful, so I used reverb to fill in the blank spots, and created a new audio file from that. That worked out pretty good. But as you see, what I ended up doing was to replace the noise between hits, not eliminate it!
Mike
-- Mike
- MacBook Pro 15.4" (9,1) - 2.3 GHz i7 16GB RAM
- OS X 10.14.1 Mojave / Windows 10 (Bootcamp) - PT running on Windows partition
- PreSonus Quantum 2
- PreSonus Studio 24c
- MBox 3 Mini
- Mackie Onyx 1640i
- Behringer X32 Producer
- PT 2018.12 (vanilla)
- Various USB2/3 and Firewire hard drives
Old 01-01-2001, 08:51 AM
Thanks Mike for your advice. I'll keep that in mind. You're a great help.
D
Calculate waveform - where are waveform views stored? levelaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-11-2010 07:18 AM
deleting the Mac HD prismtheory Pro Tools TDM Systems (Mac) 1 05-20-2005 11:12 PM
deleting drummerfreak33 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-17-2004 06:01 AM
Deleting a session defretman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-06-2003 12:59 AM
Deleting/Copy MIDI notes is not deleting/copying MIDI sustain? Mark_Knecht 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-26-2002 12:29 AM
