Old 12-30-2010, 02:11 PM
Venta Venta is offline
Default Need LE8 installed to install Pro Tools 9?
I'm selling my Mbox - and am aware of the requirements, however I don't have LE installed on my system at the moment, as had to re-install my OS.
Does 8 need to be installed to install 9?
Thanks
Old 12-30-2010, 02:17 PM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: Need LE8 installed to install Pro Tools 9?
No.
Uninstall PT and install PT9. Install the drivers first.
Check for incompatible plug-ins
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 12-30-2010, 03:28 PM
Thanks for the swift reply. .
Are all the versions of PT9 the same?
Is the 'crossgrade' version the same as the full version?
Old 12-30-2010, 04:01 PM
HD2 HD2 is offline
As long as you download the full installer, (not the updater) that is all you need. The ilok key is what will determine your version. i.e PT9 HD or just PT9.
The crossgrade isn't a "version" just a pricing structure.
Old 12-31-2010, 02:38 AM
Cheers guys - thanks, much appreciated . .
[IMG] code is Off
Pro Tools 10.3.2 wont even install! After clean windows 7 install!!! shamanrock Windows 13 12-27-2012 04:39 PM
First install of Pro Tools 9 - Logic 9 already installed - PlugIn install questions b-pole macOS 2 08-31-2011 07:23 AM
I had Pro tools installed once on this computer. Now I Cant Re-install it. why? cityboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-01-2010 02:55 AM
8.0.4 won't install with 8.0.3 installed gossamer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-14-2010 07:23 PM
New P4 2.8GHz system, new XP install, Digi001 installed, PT fails launch with DAE -4 bwherry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 47 03-17-2003 06:28 AM
