Old 01-15-2019, 07:40 AM
js_nyc js_nyc is offline
Default Help with C|24 monitoring section
Hello everyone. Have a client with the following configuration:
Mac trash can with High Sierra and PT 12.x HDX1
4 16 I/Os- all analog
3 pairs of stereo speakers on a passive switcher
Blue Sky System One 5.1 w/Bass Management Controller MK II
We need to set them up to be able to monitor both stereo (through the stereo speakers as well as the Blue Sky L/R) and 5.1 through the Blue Sky System. All of the 16 I/Os are wired into a patchbay that is normalled. At this point, we are making a crosspatch from Output 2 into the C|24 monitor 3 in order to hear the Right speaker, since the I/O is sending stereo from Output1/2 on the first 16 I/O. Is this something that can be alleviated by altering the I/O setup, or does the patchbay need to be wire swapped? And how can the C|24 monitoring system be set up to also monitor the Lt/Rt or Lo/Ro during a 5.1 mix?
Thanks, and hope to hear from someone soon.
js_nyc
15" Macbook Pro (Mid 2012) 2.3 GHz Intel Core i7
16G Memory
PT 10.3.11/ 12.5.2
003 Rack
OSX 10.8.5
ProToolsConsultant.com
Old 01-15-2019, 08:09 AM
its2loud its2loud is offline
Default Re: Help with C|24 monitoring section
Output routing for LRCLfeLsRs can be remapped in the I/O setup to accommodate your hardwired configuration.
As for monitoring both 5.1 and LtRt, send the LtRt out a different set of PT outputs to be selected as a source on the C24. The C24 allows for two stereo sources and 2 5.1 sources. Of course this depends on how the system was wired on installation.
Old 01-15-2019, 03:17 PM
Raoul23 Raoul23 is offline
This thread might help you. I was confused on rigging the c24 up and some great folks here helped me out
Connecting C24, Digi 192 with outboard?
https://r.tapatalk.com/shareLink?sha...8&share_type=t
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 3.1 Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 01-16-2019, 10:19 AM
Pretty sure the C24 requires surround to be done as LCR(which means R is on output 3 of the DB25 connector). That's how we need to route for my friend's C24 to stereo(outputs 1&3, because output 2 is C-only)
Old 01-17-2019, 10:03 AM
Thanks to all for the advice.
js_nyc
16G Memory
PT 10.3.11/ 12.5.2
003 Rack
OSX 10.8.5
Connecting HD I/O 16X16 to c24 monitoring section Caseylee412 ICON & C|24 8 07-20-2015 07:05 PM
Omni IO monitoring section question vudoo Pro Tools HDX & HD Native Systems (Mac) 1 06-10-2014 08:41 AM
Control 24 - alternate to monitoring section youbringmesuffering ICON & C|24 2 11-04-2011 05:45 AM
help with 002 monitoring section; urgent biggun1234 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-21-2009 06:45 AM
D Control Monitoring Section tandem ICON & C|24 3 09-21-2006 10:12 PM
