M-Audio Fast Track Pro with Pro Tools First
Hello,
Has anyone here has succeed to use a M-Audio Fast Track Pro on Pro Tools First ? My sound card is recognized by Windows and PreSonus Studio One but not by Pro Tools First |
Re: M-Audio Fast Track Pro with Pro Tools First
You should be able to use just about any interface with PT First. When you start Pro Tools, try holding down the "N" key, that should prompt for you to select what audio device you want to use. As long as you have the FTP drivers installed, you should be able to select it.
Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
Thank you for your reply ; when I try to select the right device, it shoes my internal Realtek sound card but not the Fast Track Pro (even it works as the main sound card on the PC), all the drivers are correctly installed
Assuming you're using Windows..
Best practice is to not use your audio interface for your computer sounds. ASIO devices are single client (for the most part), so if your computer makes any sounds (menu, error, youtube etc.) it can cause issues. I run an output from my interface into my computer sound card, and connect my monitors to my sound card so I can hear everything. I'd recommend going into Control Panel, Sounds, right clicking on any of your interfaces outputs and inputs and clicking Disable. Can you post your full system specs? Joel
Pro Tools 11.3.1 / M-Audio Fast Track Pro | skateboardharvey | Pro Tools 11 | 15 | 02-08-2017 05:10 AM |
Pro tools 10 and M-audio Fast track pro | flako15 | Windows | 2 | 05-05-2014 08:28 PM |
Using M-Audio Fast Track 8R with Pro Tools 8 LE | drjordan | Tips & Tricks | 3 | 12-19-2012 12:20 AM |
M-Audio Fast Track Pro and Pro Tools LE | Pete Seizure | General Discussion | 1 | 02-27-2009 04:53 PM |
Pro Tools & M-audio fast track | vreynoldsv | Pro Tools M-Powered (Win) | 3 | 12-19-2006 12:56 AM |
