Clip editing from the surface doesn't work
The title says it all. Am I missing something? Or is this just another thing which hasn't been implemented yet?
my blog:Tamas Dragon |
Re: Clip editing from the surface doesn't work
hmmm, I saw it done in an early version of 1.3 a few months back.
It is implemented and working. Just press the "Edit" button on the knob module from the surface. It only works on the channel strips, not the master module.
Steve Peach Stereo Missile Recordings Creative Director - Red Note Visionary Sounds: http://rednote.com.au Label: http://www.stereomissile.com/ Music Production / Mixing: http://www.stereomissile.com/musicproducer/ Mastering: http://www.stereomissile.com/mastering/ |
That's what I've done, multiple times, but no luck. This is with M10 brain.
I think it might need the display modules to work as that is how the clips are selected. So it might be for M40 only, but you should confirm that.
Clip editing requires an M40 with display modules.
Gil Gowing Principal Digimidi Technical Services |
Bit sad about this...
Accepted. :)
Just curious, is that mentioned in any of the available S6 info? I don't remember seeing that distinction made but I also didn't pay too much attention because I can't see using that feature much.
I understand the technical requirement but there is bound to be some disappointment among M10 buyers.
~Will |
The idea behind clip editing from the surface is to be able to use the display module to see what you are editing. Since the M10 can not use the display modules, the feature is not available. The same thing for M40 systems with no display modules, the feature is not available there as well.
Gil
S3 has clip editing from the surface.
Joan. |
Quantize to Grid doesn't work when set to Clip/Markers | myca | macOS | 16 | 12-28-2014 04:03 PM |
My 003 Still Doesn't Work as a Control Surface in 9.02 | rjkool | Windows | 11 | 03-13-2011 04:24 PM |
BUG (?): Match clip doesn´t work on split mono | Frank Kruse | Post - Surround - Video | 5 | 12-17-2008 06:34 AM |
ESC doesn't work on the C24 Surface with cs4 Upgrade~ | a2zproductions | ICON & C|24 | 0 | 08-03-2007 10:09 PM |
Clip Light Doesn't Work In Playback | brianpatrick | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-07-2003 09:06 AM |
