#21
Re: S6 bugs
Apologies… T
Tom Graham Avid Audio Marketing Pro Audio and Mixing [email protected] Check out our Pro Mixing Webinars : http://www.avid.com/US/resources/pro-mixing-webinars Avid Pro Mixing Blog: http://www.avidblogs.com/promixing/ |
#22
Re: S6 bugs
I don't understand the reasoning behind this? Why make a m10 customer buy a xmon if they don't need it?
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
#23
Re: S6 bugs
A simple phrase: more profit for Avid
#24
Re: S6 bugs
This entire thing should be modular. In fact, that was one of the selling points wasn't it?
There should only be ONE MTM, the M40. And it should be around $6k (it's a Windows 8 tablet essentially). Then each other module should be around $2.5k. Start with an 8 fader for $16k. I bet you'd have sold a lot more than 300 units so far (which is damn good already in my book). And then those buyers would slowly add modules throughout the life of the product creating a revenue stream. As it is now, you've got studios financing expensive base units and expanded systems, making bankers happy, but then they'll never add modules because they're too expensive. |
#25
Re: S6 bugs
We have one nasty bug, no metering on the whole surface. Not on channels, not on the masters, no gain reduction meters, nothing. Otherwise all functions work fine.
Tried to use a ASC code to report it, but it just doesn't work right now... Anyone found a solution for this?
my blog:Tamas Dragon |
#26
Re: S6 bugs
tams, are you on PT 11.2.1 ?
That has a known issue with metering & S6 1.2 Although the issue , they say, is only with the meter modules . .
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~ ~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG ~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~ |
#27
Re: S6 bugs
So far I've tried trashing PT prefs & databases, restart, changing playback engine, updating the S6 modules again, no luck. This is happening with a 6core trashcan MacPro with HDX2 PT HD 11.2.0 with a brand new S6 M10 with updated "brain" software (1.2 something).
#28
Re: S6 bugs
A little update. It seems I've found a solution for this problem, at least now all the meters are working properly.
The solution: * changed the desk id in WScontrol app to another id * re-launch WScontrol app (sees nothing on the network) * re-adjust the desk id to the original one (in our case it's id 1) * re-launch WScontrol Done, it works fine now.
#29
Re: S6 bugs
Some issues can be easily fixed by just quitting and relaunching WSControl App on your mac. :)
Steve Peach Stereo Missile Recordings Creative Director - Red Note Visionary Sounds: http://rednote.com.au Label: http://www.stereomissile.com/ Music Production / Mixing: http://www.stereomissile.com/musicproducer/ Mastering: http://www.stereomissile.com/mastering/ |
#30
Re: S6 bugs
That's a daily thing to do sadly. I truly hope that the next update is going to be a huge bug fix update with add-on features.
11.1.2 on Mountain Lion bugs bugs bugs. command+f, elastic audio, discoloration | farmfresh | Pro Tools 11 | 21 | 05-01-2014 07:21 PM |
7.3 bugs | dtrusz | Pro Tools TDM Systems (Mac) | 1 | 01-21-2007 01:00 PM |
7.3 LE Bugs? | djpaulwicked | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-14-2006 06:22 PM |
Bugs in my box - no, REAL BUGS !!!!!!!!! | Mixtrix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-25-2006 06:33 PM |
BUGS? | jnamm | ICON & C|24 | 0 | 01-09-2002 12:21 AM |
