Old 01-27-2021, 04:22 PM
JamesG602 JamesG602 is offline
Default HDX card noise on PT startup
Well it’s been an interesting week getting my 2 HD systems up and running. Got my HD native all squared away after some weird driver install issues.
Today I was setting up my single HDX card in the Avid single desktop thunderbolt 3 chassis. Everything hooked up fine and was recognized by protools.
My questions is, during most operation the fan on the HDX seems pretty quiet, but when starting up protools, the fan/card gives off a strange “whirrrrr” sound for a few seconds then stops. Is this normal behavior? It’s like the fan maxes out for a second or two then stops.
Thanks!
Old 01-28-2021, 06:42 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: HDX card noise on PT startup
Thanks!
When you first turn on the computer it does a hardware check which usually means all fans on cards and GPU cards go to full during the hardware test. So if its just running fast for the first few seconds its no problem.
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-28-2021, 10:15 AM
Mixchump Mixchump is offline
Yeah, when you first launch the ProTools application, it whips the fan up and then back down - and tends to be VERY whiny and noisy the entire time that PT is running. Shutting down the app will kill the fan on the HDX card. There are some on here that have been successful in replacing the fan with a quieter version, but I've not gone there..!..
Cheers, eh?
The program does not see at startup sound card divanno Third Party Interfaces 1 01-16-2015 10:43 AM
EMI Noise: Graphics card to HD Native card jacknprewitt Pro Tools HDX & HD Native Systems (Mac) 0 10-19-2013 09:02 PM
Noise at windows 7 startup stevep43 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-16-2011 04:27 PM
Noise on Mbox after startup Maik_Waschfeld 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-23-2002 06:53 AM
PT LE creating noise on startup jnxs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 04-13-2002 09:52 AM
