Old 12-03-2018, 11:29 PM
tomas_weber tomas_weber is offline
Default Could not complete the Import Audio
Dear Community,
suddenly this message occurs if I try to import audio in PT11.3.2.1 / OS 10.12.6
Any help? What can I do?
Could not complete the Import Audio command because Assertion in "/Volumes/Development/153787/ProTools/NewFileLibs/Cfd/MacBuild/../MacOS/Cfd_ImportAudioDialogMacOS.mm", line 559.
Old 12-04-2018, 04:40 AM
Default Re: Could not complete the Import Audio
Originally Posted by tomas_weber View Post
Dear Community,
This is a known issue of using PT11.3.2 in Sierra. You can import audio but have to do it as drag and drop; the Import menu item won't work right. It's been discussed several times here and I have first hand knowledge of it because I am doing the same thing as you. And that's because several plugins that I use require El Crapitan or higher to run and EC is the worst OSX ever foisted upon the mac community.
I don't know if this is the only issue with running PT11.3.2 in OSX 10.12.6 or are there others but it's not a show-stopper at least for me.
Old 12-04-2018, 05:42 AM
Thnx for your answer, this helps a lot. I will try it as you said.
Cheers Tom
Old 12-04-2018, 07:07 AM
Cheers Tom
Let me know how it works for you.
I've Googled for a list of incompatibilities running PT11.3.2 in Sierra but haven't found anything other than this particular thing. If you have any other problems with the PT/OSX combo I'd like to know what they are and maybe I can test here. I am running regular PT and not HD.
Could not complete the Import Audio command LPstudio Pro Tools 12 5 11-15-2019 05:16 AM
Could not complete the Import Audio Johnique Pro Tools 12 8 03-29-2018 11:20 PM
Cannot complete audio import command Engine Room Pro Tools 11 1 01-19-2016 06:01 PM
Could not complete import audio... sjbruce Pro Tools 11 4 10-06-2015 04:00 PM
Could not complete the Import Audio command because magic ID does not match ronfinch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-21-2010 02:32 PM
