Old 05-15-2006, 01:23 AM
cary chilton cary chilton is offline
Default How do I delete a trial plug in?
Hi, I have a trial BROADBAND LE plugin that is expired and it isn't showing up in my ADD/REMOVE programs. I found the . dpm file in commonfiles/DAE/plugins. Can I just delete it there or there another way I should do it?
Old 05-15-2006, 05:55 AM
spkguitar's Avatar
Default Re: How do I delete a trial plug in?
The "broadband noise reduction" plugin appears on the ADD/REMOVE dialog as "Digidesign DINR". Just remove it from the ADD/REMOVE dialog.
Old 05-15-2006, 12:59 PM
CHORDZ CHORDZ is offline
How do you do that?
Old 05-15-2006, 01:06 PM
markshan markshan is offline
Start> Control Panel> Add/Remove Programs
001, LE6.4cs69, XP Pro SP1, P4 2.8, 1 G Ram, Asus P4GE-MX board
Old 05-15-2006, 01:46 PM
I will repeat myself again, the DINr is not in my add/remove programs window. It was, when I tried to remove it, a dialogue box came saying it could delete all associated files, but opted that I could ignore or cancel. I chose ignore, but then it wiped it out of my add/remove programs. HOwever, everytime I open PT the DINr trial expiration window pops up to quit or authorize. SO, again, how can remove this dpm file?
Old 05-15-2006, 01:56 PM
spkguitar's Avatar
You did not mention that in your first post.
Delete both the *.dpm and the *.dpm.rsr files from your plugins directory if they are present. You might also want to clean the registry after that.
Old 05-16-2006, 11:25 AM
OK thanks. How can I clean my registry? go : regedit and ? How do this safely?
Old 05-16-2006, 11:37 AM
spkguitar's Avatar
There are several free registry cleaner programs available. Google: "free registry cleaner".
One I've used is cCleaner.
Old 05-16-2006, 01:53 PM
gotchya THANKS!
how do i delete "DV Toolkit" trial?(searched already) rjd2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-14-2007 12:33 PM
How do I get rid of the trial version of plug-ins? Lexvortex 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-09-2006 02:27 PM
How do you delete the free trial D-fi plugin? Siberian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-18-2005 03:15 PM
Plug-ins for trial use? RUNDMOD4MUSIC Tips & Tricks 1 02-16-2005 02:36 PM
Delete Trial of Digitraslator and Mach Control? Mount Royal Pro Tools TDM Systems (Mac) 2 12-10-2004 03:41 PM
