Old 11-30-2011, 06:48 AM
W Sound W Sound is offline
Default Pro Tools LE 8 Midi Pitch Bend Problem
Here's the problem...
I'm working on some dubstep/dance recordings. When using any VI in Pro Tools, the Pitch Bend works fine when I'm not recording, but as soon as I start to record in pitch bend info, it seems to get 'stuck' on certain notes along the way (basically, it doesn't monitor the triggered sounds correctly while recording).
It is, however, recording the midi info into the session correctly, because if I play it back after recording, the 'sticking' of notes doesn't happen any more.
This is not a controller problem, as I have tested it out on several midi controllers, and everything is fine while recording except the pitch bend!
please help
Old 12-09-2011, 02:09 PM
Default Re: Pro Tools LE 8 Midi Pitch Bend Problem
...I'm guessing that silence means I am going to have to upgrade to PT 10
Edit pitch bend midi data bwandon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-24-2018 08:20 PM
MIDI track not reading pitch bend data? kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-11-2009 07:04 PM
Does pro tools have a pitch bend effect? davetheone Tips & Tricks 14 01-29-2009 06:15 AM
MIDI Pitch bend question, please? William 2014 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-30-2006 11:53 AM
MIDI : Pitch Bend Muxlow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-01-2003 09:28 PM
