Old 12-01-2010, 12:31 PM
Rhythmproject Rhythmproject is offline
Default How do I select every other region in PT8? Possible?
Hi Everybody,
As written in the title: How do I select every other region in PT8? Is it possible to do so? In OSX 10.6, it is standard operation, in the finder for example, to be able to select a random assortment of files in a particular folder by holding down COMMAND and clicking instead of SHIFT (Holding SHIFT and clicking a file and then another file elsewhere in a folder will also select EVERY file in between the two that were clicked on).
I can perform this type of selecting in Logic 9's arrange window but for some reason can't figure out how to do it in Pro Tools. Any insight is helpful!! Thank you!
Old 12-01-2010, 12:40 PM
Meads Meads is offline
Default Re: How do I select every other region in PT8? Possible?
You can do that with the grabber tool in object-mode (with the squares on the hand), by holding shift and clicking the desired regions.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Select in Region bin won't select region in edit window? innerbooty Pro Tools TDM Systems (Mac) 3 03-24-2013 11:04 AM
Can't select a region with fades... austinere macOS 2 08-17-2011 04:01 PM
7.3.1 Region Select Centered BOO!! Help me Stop it KingFish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-28-2007 10:36 PM
When I select a region adjacent regions are also! potex Tips & Tricks 2 12-27-2006 11:12 AM
Can't select region to edit Hot Voice 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-09-2006 12:08 PM
