Old 11-03-2002, 12:10 AM
Up Late Up Late is offline
Default Suddenly Slow
All of the sudden, my session file has become slow. [img]images/icons/shocked.gif[/img] Clicking in the scroll bar to scroll up results in a lag of about 2 seconds. Almost every procedure I'd like to do is now slow. Selecting tracks, selecting anything, all slow. Session does play fine, however. Other sessions are not slow. I've tried loading all tracks into a new file, but no improvement. Any suggestions?
HD 2, 192, 192D, G4 Dual Gig Quicksilver
Old 11-03-2002, 07:31 AM
studiojimi's Avatar
studiojimi studiojimi is offline
Default Re: Suddenly Slow
back up your hard drive
run norton
opimtize if needed
take 2 aspirin and call me in the morning
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
Old 11-03-2002, 09:02 AM
JamerJ JamerJ is offline
Are going heavy on RTAS or processor
based functions? Even an open Absynth
TDM plug can bog things down...
Jim
JSM Music NY/LA
Old 11-03-2002, 09:33 AM
I had just optimized the disk a few days before. No RTAS plugs at all. An earlier (and almost identical version of the file) has no problems. I'm using a lot of aux tracks for live input, about 8 TDM plugs, that's about it. It started to happen after recording a MIDI track.
Old 11-03-2002, 09:37 AM
Lee Blaske Lee Blaske is offline
A MIDI feedback loop is a classic system slower downer. It can be occuring on channels that you're not monitoring. Watch your activity lights on your interface. Also, experiment with unplugging all the MIDI devices from your interface. If the problem disappears, reconnect devices one by one until the problem reappears.
Lee Blaske
Old 11-03-2002, 01:46 PM
Thanks everyone, I found the problem. Having the Movie track visible with it's track view set to frames causes every move I make take a lot longer. Setting the movie track view to BLOCKS or just making it invisible returns everything back to normal. [img]images/icons/cool.gif[/img]
edit and trans windows suddenly slow bleach macOS 0 12-30-2011 07:59 AM
Pro Tools MP 8.0.5 is suddenly annoyingly slow philmont702a Pro Tools M-Powered (Win) 0 10-26-2011 03:54 PM
Suddenly slow save times digidesigner Pro Tools TDM Systems (Win) 3 09-16-2011 03:16 AM
Pro tools suddenly slow! wonderland 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-02-2010 03:01 PM
session suddenly running extremely slow jonahjonahjonah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-16-2006 07:32 PM
