#121
Re: I Got Pro Tools 7.3 to recognize 2.7GB of memory- Here's how
Intel Quad Core
4 GB RAM WIN XP SP2 m-powered 7.4.cs2 Laatido work fine: i can use 2.8GB only, instead of 1.5 without Laatido. Problem: i have installed 2 Duende PCIe. If laatido is enabled, then duende pcie crash. Disable laatido again :-( alex |
#122
i have tried this trick and got it to work. but there was one flaw in the whole thing. when i would record a track, the waveform would not show up until i was done recording. not to helpful if you like to meter your levels while recording. to me, if digi wanted it to run like this, they would have done it for you. but thats just me.
#123
Did you have Pro Tools in Quick Punch? If so, in earlier versions of Pro Tools, the waveforms were drawn when recording was stopped. IIRC, it was 7.2 when waveforms were drawn using Quick Punch and (HD only) Track Punch.
Cheers,
#124
not sure what you mean by quick punch. im running 7.3.1 cs7. if you could help me out and get it going it would be great.
#125
just checked... i never used the quick punch feature. so it cant be that.
#126
Re: I Got Pro Tools 7.3 to recognize 2.7GB of memory- Here\'s how
For example: multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Micro soft Windows XP Home Edition 6GB" /fastdetect /noexecute=optin /6GB |
#127
The part use applications executable file; is this Pro tools File? |
#128
Hi im wondering this as well. just downloaded the utility in the first blank window do i put the protools.exe file?
#129
OK got it to work, very easy. How do i know that im seeing more memory with PTLE?
#130
How do you check how much memory is allocated to PT??
Apple: MBP 2.53 - 4G RAM HDD 500G, iMac 27 inch 1TB ProFire 2626, MBox Micro, PTMP 8, NIs, Strike, POD Farm, Logic 9, EJ Strat, 52 Tele RI, MB Mk 3, PRS CE22, Epi Casino, PBass, Variax, L6XTL, M13, DRRI, BM iGuitar, GR-33, KeyStation 88, Axiom 49 |
Pro tools 8 doesn't recognize 192 i/o | supafuzz | macOS | 8 | 01-14-2014 08:12 AM |
Pro Tools HD 9 Doesn't Recognize 2nd 192 io | oechols | Pro Tools 9 | 2 | 05-09-2011 06:18 AM |
Pro Tools can't recognize 192 I/O | Juraj Bernáth | Pro Tools TDM Systems (Mac) | 5 | 11-03-2010 08:46 AM |
Pro Tools LE does not recognize more than 1 CPU | done_411 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-22-2010 06:32 AM |
Pro Tools Does Not Recognize M Box | beelofi | Pro Tools M-Powered (Win) | 3 | 01-15-2007 10:21 AM |
