Video Codec dnxhd
I have 3 questions
1 - Where can I get the dnxhd (Video) codec 2 - Will it work on Pro Tools 8LE 3 - If not, what are other choices for video codecs compatible with PT 8LE |
Re: Video Codec dnxhd
what are you using for your video out of your LE rig?
an OG analog Mojo will use the HDx codecs nicely there is a codec pack (or there was) for QT to see HDx codecs here http://avid.force.com/pkb/articles/e...nload/en423319
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
I am not using anything for my output. I am trying to import video into pro tools so I can sync music :)
The codec says it's "Codecs LE and PE bundled with Media Composer 6, Symphony 6.0 and Newscutter 10" will these work on pro tools? Thank you Craig |
LE for Pro Tools and other apps
PE is for Media Composer you may need an older version http://avid.force.com/pkb/articles/e...ility/en350875
Thank you so much Craig
I know this post is ancient, but it is literally the only thing on Avid's site I can find that's even close to answering my question. I need the DNxHD codec (that I used to have) on our old rig, running PT 10 HD|Accel on a hackintosh with Mac OS 10.6.8. OR I need an uninstaller for the version that's on the computer which doesn't work. I can keep trying old versions of the codec from https://www.videohelp.com/software/A...ns#downloadold but I can't install an older one over a newer one and can't find an uninstaller anywhere.
system drive\Library\Quicktime
Delete all the AvidAV* codecs component files
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 Last edited by BScout; 01-10-2019 at 01:01 PM. Reason: wrong path. fixed |
Thank you. Strange thing, though, there is no Quicktime folder in my Library folder. Perhaps that's why the codec I have installed isn't working...
Just thinking out loud but you could do a spotlight search to find one of the files in order to find the folder they are nested in. An example filename is: AvidAV1xCodec.component I would use wildcards to search though as I don't know what version you currently have installed and the names might be different. The variable part is the middle. This is consistent part for all the files: AvidAV*Codec.component (ie, the "1x" has many variables between all the files) You can only do a wildcard search in Spotlight as a raw query in the advanced Spotlight fields (not just the normal Spotlight magnifying glass area) so you might have to look that up if you haven't done one before.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 Last edited by BScout; 01-10-2019 at 03:00 PM. |
DNxHD Codec and HD Native don't mix | ggegan | Post - Surround - Video | 7 | 02-05-2013 06:20 PM |
PAL video codec for PT HD 8.1 on a PPC Mac | Larold | Post - Surround - Video | 8 | 09-24-2011 10:05 AM |
Video Satellite LE, Decklink, DNxHD - How? | SHUK | Post - Surround - Video | 3 | 05-12-2011 05:14 AM |
Video Satellite LE + AVID DNxHD | RenderBot | Post - Surround - Video | 3 | 07-15-2009 03:30 AM |
VC-1 video codec | lxaudio | Pro Tools TDM Systems (Mac) | 5 | 04-06-2009 02:23 PM |
