Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 10-19-2008, 08:57 PM
czarthp czarthp is offline
Default setting external drive record
I am trying to use my external drive to record to in tools, I have to tried to set this drive to record in pro tools HD and M-powered and it says that it can not be designated as an audio record volume because it is not a valid audio volume. How can I get pro tools to see this hard drive as a record volume. It is a Iomega portable 160gb usb/firewire harddrive.
Old 10-20-2008, 05:59 AM
jre3132 jre3132 is offline
Default Re: setting external drive record
what is the drive speed? Is it bus powered?
Mac Pro 3.7 Quad Core Intel
Mac OS X 10.13.2
PT Ultimate HDX 2019.10
64GB RAM
HDX I/O 16x16 Analog
HDX I/O 8x8x8
Old 10-20-2008, 07:12 AM
the speed is 5400 rpm and yes it is bus powered by firewire, I only use it with firewire
Old 10-20-2008, 07:20 AM
thats your problem. The drive is too slow for Pro Tools. Pro Tools requires at least a 7200rpm drive.
And, bus powered drives aren't the greatest for recording. I've never had much luck with them for anything other than transfer/portable drives.
http://www.digidesign.com/index.cfm?...4&itemid=23126
Mac OS X 10.13.2
64GB RAM
HDX I/O 8x8x8
Old 10-20-2008, 08:19 AM
I can record to my macbook's internal hard drive and I"m sure its 5400, or does pro tools see the internal differently? So USB is better for recording than firewire?
Old 10-20-2008, 08:25 AM
you can record to an internal drive, but it is not recommended and you wouldn't be able to get the track count and performance you could get out of an external firewire HD. It can also lead to errors and crashes.
Hard Drive requirements - all types.
http://www.digidesign.com/index.cfm?...4&itemid=23140
USB is not recommended at all.
USB 2.0 Hard Drives
USB hard drives are NOT recommended or supported for use as recording drives. Limited testing has shown that performance with USB drives is inferior to that of FireWire drives.
Mac OS X 10.13.2
64GB RAM
HDX I/O 8x8x8
Old 10-20-2008, 12:52 PM
thats what I thought, since you said firewire wasn't I thought you were suggesting to go with USB.
I figured out why I couldn't record to the drive, it was not formatted for mac. I thought I had done this before but I geuss I didn't, when I checked it was formatted to fat32
Old 10-26-2008, 01:58 AM
Andy Thornton Andy Thornton is offline
Wrong, and wrong. Protools will happily record and playback to/from a 5400rpm drive, even a 4200rpm drive, only with reduced track count. I do this regularly with my portable system. Digidesign specify 7200rpm as a minimum requirement to achieve specified track counts.
Secondly, bus powered drives are only a potential issue if your hardware has under-specified bus power capabilities. Some early Macbook Pro's had rather keen protection on their Firewire bus power which led to power being shut off as a protection before reaching the usual limits. None of this is a Protools issue.
If a drive is inaccessible for recording, go to Workspace and check that the drive(s) has an 'R' in it's 'A' column.
Setting up External Hard Drive tbowman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-29-2007 01:52 PM
setting up external drive Mr Layz Pro Tools M-Powered (Win) 1 11-16-2006 05:25 AM
setting up external drive terryd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-09-2005 03:23 PM
Error when setting hard drive to "record" Sarzzo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-13-2004 07:42 AM
Setting up an external drive using a "used" drive basschair 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 10-15-2003 11:45 AM
