CPU Power for use for PLUGINS
Im currently using a powerbook. I've always used this and never had problems with cpu power but recently i've been using new plugins by digidesgin... called dynamics III... I use their eq and compressor on basically 7 tracks. I usually remove and then have no problems but is there anyway to use all without pro tools telling me "cpu power use and disable some RTAS plugins". Then again when i use regular digidesign compressors and plugins i have no problems with this.
Please help. |
Re: CPU Power for use for PLUGINS
What version of ProTools are you using? And what speed is the CPU in the powerbook, how much RAM does it have, and what kind of external hard drive are you using?
You can also view the 'System Usage' window and see how much CPU you're using in a particular session, that should give you an idea of when you're getting close to hitting the ceiling. |
im using pro tools 6.9cs4...... how come i never have problems with regular default pro tools plugins cpu wise but with dynamics III i do.
Hmm, Dynamics 3 on my system eats a little more CPU than the regular compressor, but it's barely a noticable difference. Maybe try removing the plug-in and re-installing it. You could also try the other steps outlined in the "General Troubleshooting" thread.
And please post your system specs, I know it doesn't seem important but you never know what might be causing a problem, and every bit of info helps. |
PU Type: PowerPC G4 (1.2)
Number Of CPUs: 1 CPU Speed: 1.5 GHz L2 Cache (per CPU): 512 KB Memory: 1 GB these are my specs |
i need some feedback on what to do here.... reinstalling and uninstalling did nada.
DynIII and EQIII use more CPU. after trying the troubleshooting steps at the top of the thread, make sure your hardware buffer is at 1024 and see if that helps.
G5 1.8X2/3gigRAM/Mbox/7.4 (retired) MBP C2D 2.4/4GigRAM/Mbox/8.0.1 iMac i7 3.4/16GigRAM/10.0.1 |
Multiple plugins take up to much computer power? | DaMixG | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-20-2007 10:09 AM |
How many plugins - Cubase sx VS PTMP 7.1 cpu power | sonuslab | Pro Tools M-Powered (Win) | 4 | 07-07-2006 12:56 AM |
G5 running out of CPU power (minimal plugins!) | timdog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 01-30-2005 03:03 PM |
Out of CPU power with three plugins on | sabayachi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-17-2003 10:54 AM |
CPU power vs plugins | mister | General Discussion | 3 | 02-02-2001 10:00 AM |
