#21
Re: Workaround for lack of side chain delay compensation
Linked below is a pic of your method but I have delay inducing plugs on my trigger track. This is definitely giving me a hugely noticeable flam. https://app.box.com/s/e4a6q6plsiyfwcojt4a1301v78re7lbr
Mac Pro 3.5GHz 6-core (6.1, "trash can") Monterey 12.7.3 32 GB RAM Pro Tools|Ultimate 2023.12 HD Native Thunderbolt HD I/O 16x16 Analog |
#22
Have you considered a simple hardware solution, inserting a compressor and using a cloned track as the trigger? Would take away the offline bounce, but would offer so many more possibilities .
Ken Morgan Midland, TX It Doesn't Matter What I Did Then - What I Do Now Is What's Important 2017 Intel Mac Mini, 32G, PT 2023.12 Studio, Presonus Quantum 2626 and a bunch of stuff via ADAT |
#23
However, the method you offer, while likely a solid one, kind of defeats the purpose of this thread which is to get to the bottom of why Avid's Pro Tools HD mixer doesn't behave like an analog mixer. Obviously we know there are limitations with plugins in a digital mixer environment because they're not hardware and they induce delay... it's just that ADC for help with making our 3rd party plugin collections friendly to use in all scenarios doesn't take into account sidechain routing, particularly in complicated mix setups that might be ever-changing and you compose and/or mix. ADC is pretty solid-ish... but not quite there when it comes to sidechains. Seems like Avid's response has been that you need to 1.) use an HDX system to have this "luxury" and 2.) only be using AAX DSP plugs in your sidechain routing so that the HDX setup can take care of ADC for those "behind the scenes" aux sends, etc. Just a shame that ADC exists in PT but only applies to track output routing, not track-to-track routing. Look I'm all for limitations. I think they can be a good thing in the studio. Keeps you fresh. Keeps you problem solving. But I just see PT's implementation of ADC as an incomplete thought. We're close. So close. But just not quite there. I love sidechains, what can I say. I think they're one of the most powerful mix tools there is... but that's just me. And I bought Pro Tools HD to be a be-all-end-all mix solution, in the box and out. Oh well. That's all for now.
#24
hey oliver,
you dont need to have plugins on the trigger track. if you do need to process it, simply clone it as i said and use the clone sans plugins (muted with send pre fader) as the trigger track. make sense? the point of all this is to have the delay automatically compensated for, if you have to change a setting every time you add or subtract a plugin in a complicated mix, that is not a workable solution IMO. |
#25
Any suggestions? |
#26
possible solution: I did force-enabled Delay Compensation (so the text turned blue), I am not really sure why, but the sidechained track lined up again. |
#27
I have a definitive and relatively simple solution!
No track nudging necessary. 1) Duplicate whatever track you want to trigger the sidechain compressor, call it "SCAudio" or something. 2) Now, click the output of that duplicated track and hit "new track" and send it to an Aux track and name it "SC" or something like that. 3) Now, here's the kicker, go down to the delay compensation box at the bottom of the AUX track and right click on the "cmp" section and hit "Disable Track Compensation." 4) Now send the output of the AUX track to whatever bus you'll be using for the sidechain/key input. Now it will be perfectly synced! This works because audio tracks do not allow you to disable delay compensation on a per-track basis but aux tracks DO. But we need an audio track to hold the trigger audio so sending it THROUGH an aux before hitting a bus allows us to offload delay comp duties onto the aux track and then disable it on the aux. I really don't know why disabling delay comp makes it sync up but I know that it does! |
#28
not sure what is up, but i tried everything you said (excited to see if it worked!) and couldn't get it to work, sadly. Still tons of delay when using lots of plugs on trigger track (which is basically the achilles heel of the ADC issue with side chains in the first place). I'm on HD Native, PT12HD, but it wouldn't work for me. Best solution for me is still to copy trigger track and commit that audio and/or hard bypass any delay-inducing plugs on the trigger track so that total delay for trigger track is ZERO.
#29
Will Avid please just fix this already for all versions of Pro Tools? Why even offer an 'out of time sidechain' function? Just plain daft.
#30
no side chain delay compensation for HD Native users | OliverH | Pro Tools 11 | 50 | 09-02-2017 02:36 PM |
Side chain delay compensation fixed in PT HD 12 using Native card? | OliverH | Pro Tools 12 | 5 | 05-18-2016 08:39 AM |
Delay Compensation using Side Chain | Oblivion777 | Pro Tools 10 | 4 | 10-11-2012 01:22 PM |
Delay comp and Side Chain Issue | jimmyzk | macOS | 2 | 10-01-2012 02:46 AM |
