Old 11-20-2004, 07:18 PM
Cipher Cipher is offline
Default Multiple Digidesign Midi I/O Interfaces?
Is it possible to connect multiple Digidesign Midi I/O interfaces together? If so, how would you configure this set-up? Thanks in advance.
Cipher (M.I.M.S.)
Old 11-20-2004, 08:01 PM
Default Re: Multiple Digidesign Midi I/O Interfaces?
I can't say for sure but I seriously doubt it. Maybe someone else has more info.
Old 11-20-2004, 08:12 PM
Why not? From the Midi I/O Manual:
Up to four MIDI I/Os can be connected together for a total of 32 input ports and 40 output ports (Windows), and 40 input and output ports (Macintosh)
They're USB devices, you'd connect them all to a hub.
Quad 2.5 G5, 4.5G RAM
Old 11-20-2004, 08:13 PM
bb_aus bb_aus is offline
not sure about the Digi MIDI i/o check the documentation
Edirol (and i think Midiman) allow up to 4 Midi i/o devices
how many midi ports do you need, im sure 32 ports yielding 512 channels will be enough
i would look at 2 Edirol UM-880 i have 1 and it works flawlessly with Pro Tools and every other app
they are also cheeper than the digi MIDI i/o
Old 11-20-2004, 10:37 PM
The nice thing about the Digi MIDI I/O, when used with ProTools, is MIDI timestamping. The net effect should be very tight MIDI timing even when using a whole bunch of external MIDI devices. The documentation is sketchy, I can't tell whether the MIDI I/O timestamping can only be used by ProTools, or whether ProTools can use timestamping with any non-Digi MIDI interface.
Old 11-21-2004, 02:22 AM
Cool!! Thanks for all the help.
Cipher (M.I.M.S.)
Old 11-21-2004, 03:54 AM
never connect audio or MIDI devices to a USB hub run each from its own USB port
Old 11-21-2004, 01:46 PM
That's ridiculous, and the Digidesign manual explicitly states that you should use a hub for multiple MIDI I/O. Either a powered up, or unpowered - if unpowered, use power supplies on the MIDI I/O's.
Multiple USB ports on a computer are usually a hub, anyway.
Multiple interfaces to PT9 towelhead macOS 3 05-26-2011 10:18 AM
Multiple interfaces CME Pro Tools 9 37 02-07-2011 03:13 PM
multiple M-Audio (and DigiDesign) interfaces on the same computer marcnyc Pro Tools M-Powered (Mac) 5 09-02-2008 07:50 PM
Multiple MIDI interfaces with PTLE... jbr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-22-2001 12:52 AM
Multiple MIDI interfaces with PTLE... accession MIDI 1 05-19-2001 12:39 AM
