Automation issues + VCAs w/ 003
Hi!
Despite updating to 2018.1.0, utilizing Thrasher and just now a total re-install of PT, databases, preferences as well as new 003 drivers I still have a couple of issues that someone else might have found solutions to? Been having issues since later versions of PT12 (can't recall exact version) with volume automation on MIDI clips/regions. If I start playback by marking a clip on the timeline or playback from timeline marker/memory location it won't read the first automation points. The volume is often much higher than the fade in effect I want - even higher than max automation level. Everything works fine if I start playback ahead of the clip. Wouldn't be an issues normally but on several sessions I need to do tons of prints from the exact start of most clips. :/ I've been going through all automation on all tracks on several sessions and I've noticed an interesting bug that occurs that might have some correlation with this issue (like I would know? :) Let's say I've duplicated or moved a clip to a new location with all automation copied as well. The first automation point at the exact start of the clip can't be deleted by hovering the mouse over it using Alt+Click. I have to do a selection that starts before and after the point I want to delete to remove it. If I add a new automation point there's no hassle, just the copied/duplicated one. Second issue is with 003 and VCAs. With 2018.1.0 the 003 Fader won't recognize any VCAs on loading up a session. If I add new VCAs to the session they show up and works just fine but doesn't show up next time I open up the session again. Anyone still with 003 and has the same issues?
Pro Tools 2018.1.0 | Win10 Home | i7-6800K 3.4GHz |32GB RAM | Digi 003 Console | Samsung 960 EVO (System drive) |
Re: Automation issues + VCAs w/ 003
Bump
VCAs Rec Button ?? Stems using VCAs | Zak7 | macOS | 6 | 10-26-2017 07:51 AM |
VCAs Spill bug | bucha | Avid S4/S6 | 7 | 09-19-2017 08:00 AM |
Can't write automation to vcas!?! | fnordling | Post - Surround - Video | 3 | 09-22-2011 02:04 PM |
What's on your VCAs? | mtung | ICON & C|24 | 8 | 08-17-2009 12:52 AM |
automation issues (re-writing automation when it shouldn't) | revere | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-13-2008 02:41 PM |
