My DI guitar input level is hotter when recording?!
Here is my set up chain
I usually get a level of -10db or so. When I hit record the volume jumps up about 3 to 4 DB. I usually throw the trim plug after the amp simulator to bring it back down to where I want it to be. Not that this is a major issue, but what is causing this? Any insight would be great. Thanks Justin |
Re: My DI guitar input level is hotter when recording?!
Just a guess. Could you have post fader metering happening and have the fader turned down? If this is the case, when you are recording, you are seeing the actual level being recorded. When you play back, you are seeing the actual level being heard. Research "Pre-Fader Metering."
You can find that option under the menu bar Options - Pre-Fader Metering.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course Pro Tools HDX 2023.9 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.7.4 Noisebox Studios -Utah Recording Studio |
Just like drummers sometimes you put the cans on and hit record things get louder. One of the best talents to tracking drums is to get the drummer to actually play at record volume for sound check and drums s,u .
I like to just mic it up at say were ready than let him do a few passes then say now we have do everything , Just tricking you to get a actual level to work with . Drummers acoustic players that are not super talented always play louder . and singers talk loud to with out knowing it . This could be your issue but more than likely its the answer above this. |
Check under Preferences->Operation "Link Record and Play Faders" ...
WombatStudio.Org • Digital Recording, Mixing and Mastering in Gibbsboro, NJ • USA "It's not the gear ... it's the ear" |
Input shows up 10dB+ hotter than actual input | nteeter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-10-2008 03:09 PM |
Input level changes during recording on 002 Rack. | decoy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-14-2006 03:50 PM |
Mbox Input level only half w/ full gain recording | mgfan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-05-2005 02:38 PM |
New User - Digi002 Level Setting - Guitar input | rlporter5 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 12-22-2003 07:02 AM |
getting the overall level hotter! | jacko32 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 03-06-2003 07:17 PM |
