Old 09-07-2002, 05:30 AM
Will Russell's Avatar
Will Russell Will Russell is offline
Default new ProControl problem with HD
Since I upgraded to HD the switches/lights in the plugin select section of the ProControl are not accurate. When I first show the plugins for any given channel, the lights do not accurately tell the in/bypass status of the plugs on that track, rendering them useless as indicators. Anyone else have this problem? It is very annoying.
Will Russell
Electric Wilburland Studio
https://linktr.ee/wilburland
M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock
M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS
Old 09-07-2002, 05:53 AM
Chris Lambrechts's Avatar
Chris Lambrechts Chris Lambrechts is offline
Default Re: new ProControl problem with HD
hmmm .... didn't notice anything like that .... will experiment and report back .... what version are you using ????
Chris Lambrechts
Applications Specialist- Live Sound
Old 09-07-2002, 05:04 PM
PTPerson PTPerson is offline
Yeah I have a few odd things going on like you Will.
The bypass lights would be lit on the side even if there's no bypass etc.etc.
Then when I select the plug in for parameter dialling the bypass switches would stay lit.
Some odd things happening in the channel matrix too such as, If I go out of plug in editing mode and select "select" in the matrix the DSP plug "DSP Page Lights" would stay lit in "select" mode.
All just niggly little bugs.
[img]images/icons/smile.gif[/img]
ProControl Output problem michael c ProControl, Control|24, Command|8 2 09-29-2008 08:51 AM
procontrol fader problem blvdrec ProControl, Control|24, Command|8 1 12-17-2004 08:14 AM
Procontrol Fader Problem soundbird Post - Surround - Video 1 06-01-2004 11:38 AM
Wiring problem with Procontrol Wooster Pro Tools TDM Systems (Mac) 1 11-01-2000 10:46 AM
Wiring problem with Procontrol Wooster Tips & Tricks 0 11-01-2000 09:32 AM
