Old 05-31-2011, 01:09 AM
Lemonhans Lemonhans is offline
Default shift + m does not mute track
Hi, when I click in a track, I'm able to shift + I or shift + s to input select or solo a track, but shift + m doesn't work. It only puts the playback cursor one track down (like keyboard focus + m does). I'm on a Azerty-keyboard. Does anyone have an idea why this doesn't work. Or do I need to use another key combination? thanks, this would be a real time saver!
Old 05-31-2011, 01:11 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: shift + m does not mute track
Apple+M
Chris
Producer, Engineer,
www.ukmastering.com
Old 05-31-2011, 01:22 AM
sorry Chris, this doesn't work. I have my cursor in one track and the track is selected; when I use apple+ M, nothing happens.
Using shift + m only extends my blinking cursor line (playhead) to the track underneath.
Old 05-31-2011, 04:13 AM
suicune suicune is offline
Apple-m is the shortcut to mute a region, it won't do anything unless you have something selected.
The M key on an azerty keyboard is where the ; key is on a qwerty, I think this is the problem - as ; is the commands-focus key for move cursor down a track. Try the ? key instead, I think this the key you have where the M is on a qwerty.
M2 Studios
Wolverhampton, UK
http://www.madhat.co.uk
A way to mute a track while un-muting another track w one click? DrummerGuy09 Tips & Tricks 7 06-12-2022 07:57 PM
Send mute/solo follows track mute/solo pre-fader Roger_Jam_Jet Windows 3 09-24-2017 01:59 PM
Mute / Solo "Shift +" shortcuts don't work kaiserpathos macOS 2 08-14-2011 10:39 PM
Can't Mute or Change Volume on Audio Track and Instrument track FunkTools 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-10-2010 04:40 AM
Mute on audio track switches off when I play the track el biciclista Pro Tools TDM Systems (Mac) 3 07-29-2003 10:54 AM
