Mute Shortcut (M) stopped working?
Suddenly the M shortcut started to minimize the Edit Window instead of muting the selected region.
For some reason OSX has taken control over this shortcut. Tried to override the system by assigning the shortcut manually in System Preferences > Keyboard> Keyboard Shortcuts but can't enter the M shortcut cause it , as expected, minimizes the pref. window too The Mute Regions command works though under the Edit menu when clicking on it using the mouse Trashed PT preferences , rebooted, no go . Anyone has an idea what could've happened? Thanx a lot in advance ! PT LE 8.04 OSX 10.6.6 |
Re: Mute Shortcut (M) stopped working?
It keeps doing it , anyone has an idea why ?
Cool thing is that M doesn't minimize the edit window when muting midi notes ... ha ha ha, now that's a mystery to me |
Not quite sure, what the "M"-Key does when it is pressed alone, but maybe, your apple-key has a problem ?
Mac Mini M1, 16 GB Ram, OSX 10.181.1,Focusrite Scarlett 18i20,Behringer ADA 8200,Pro Tools 2022 2xGlyph hard drive 750GB |
Thanx for trying to help Talisker , ( the M key alone nudges the region to the left)
Anyway, i don't think is the apple key, i'm using two keyboards and all four 's (right and left for each keyboard ) mizimize the Edit window but just when muting audio regions . For example E cuts perfectly well, Z undo, etc.. You can imagine what a pain in the a.. is having this shortcut dead. |
"Next start/end"- shortcut stopped working...? | renbak | Pro Tools TDM Systems (Mac) | 6 | 12-07-2010 01:59 AM |
mute singel notes shortcut??? | JaiL | Pro Tools TDM Systems (Mac) | 3 | 10-04-2007 03:13 PM |
keyboard shortcut "F12" record, stopped ??? | dobryden2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-14-2007 01:21 PM |
Global region mute shortcut? | Flamethrower | Post - Surround - Video | 3 | 04-20-2005 02:47 PM |
Shortcut to mute region? | vze24x2x | Tips & Tricks | 10 | 02-23-2004 11:47 AM |
