Re: Automation rat\'s nest w/ Object Grabber
I've had this same problem; automation doubling back on itself, crossing over itself, breakpoints that can't be erased. I like to keep my automation clean, but this bug takes up a lot of my time trying to sort through the mess.
Gills |
PT5.1.1/MixPlus, OS9.0.4, 9600/G3-300…
I believe I have observed a bug involving the object grabber. I was wondering if anyone else has seen something similar. In video post I often sound design :30 spots and then have to create :15 cut downs. I use the object grabber to copy/paste groups of regions. The source regions have volume/pan automation that consists of anchor points at the beginning and end of the region, i.e. a simple level adjust. On rare occasion some of the automation will playback strangely. When I look at the automation in the edit window, there are instances where the automation line will double back on itself. Weird! One time I poked at it a little (in session – gotta keep moving) and if I started playback before the jumble, PT would play one iteration while if I started on the jumble, it’d play the other iteration. |
Object grabber bug? | jturner | Pro Tools TDM Systems (Mac) | 1 | 01-07-2008 11:27 PM |
object grabber in PT LE??? | Lane McGiboney | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-09-2005 12:08 PM |
bug with object grabber | PTLance | Pro Tools TDM Systems (Mac) | 25 | 06-19-2003 08:32 PM |
Automation/Object Grabber Bug | who | Pro Tools TDM Systems (Mac) | 2 | 08-04-2002 08:00 AM |
object grabber bug? | KingTor | Pro Tools TDM Systems (Mac) | 2 | 05-05-2000 03:05 PM |
