Old 08-10-2017, 12:23 PM
TwoSouls TwoSouls is offline
Default Rendering Clip Fades for Export PT 11.3.1
I have hundreds of individual clips I want to export. I've gone ahead and applied a short 25ms fade in and fade out to the clips. The goal is to export these clips as individual files via the "Export Clips as Files" command. But I can't get the fades to render.
In the past, I've either "applied clip gain" or used the AudioSuite's "Gain" plugin, selected "create individual files" and "clip by clip," and voila, my fades are rendered. But now it seems "clip by clip" is greyed out in the AudioSuite Gain plugin, and nothing I do seems to render the fade.
Any help?
Old 08-12-2017, 05:41 AM
Default Re: Rendering Clip Fades for Export PT 11.3.1
If you're talking about separate fade files those went away with PT11. The fades are part of the regular audio.
Jack
QAPLA!
Old 08-12-2017, 03:46 PM
Thanks for the response! Not talking about fade files - simply looking for a way to batch destructively render/print existing fades in order to quickly export 100s of clips via the "Export clips as files" command.
Old 08-16-2017, 11:03 AM
joachim's Avatar
joachim joachim is offline
"Create individual files" and "entire selection" should work. Does it ?
"Clip by clip" is greyed out, because it is not applicable. It would be applicable for normalizing, etc, because all the clips need different treatment.
In the audiosuite gain GUI, next to "gain", is "playlist" selected and next to that is "use in playlist" highlighted in blue ?
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
x form rendering blank files when choosing clip by clip audiosuite dj_grimmace AAX Plug-ins 2 06-21-2017 11:29 AM
x form rendering blank files when choosing clip by clip audiosuite dj_grimmace Pro Tools 11 1 03-04-2017 12:35 PM
AAF Export without rendering fades? JonesH Pro Tools 10 1 10-20-2012 04:16 PM
PT8 on a G5 not Rendering fades basslineb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-06-2010 05:12 PM
Fades not rendering... Anibal Pro Tools TDM Systems (Mac) 5 11-21-2006 02:22 PM
