Old 06-24-2017, 07:22 AM
yoerik roevens yoerik roevens is offline
Default Eucon 3.6.1 S3 LCD font oversized?
anyone else seeing this?
suggestions?
rebooting S3/pc/protools/Eucon doesn't help.
https://drive.google.com/open?id=0B2...zZ0MnUySVYwcDg
Old 06-24-2017, 08:21 AM
EddieJones's Avatar
Default Re: Eucon 3.6.1 S3 LCD font oversized?
Sounds familiar, I'm trying to find out what is causing this and a workaround. What is you display configuration, number of monitors and their resolutions ?
Old 06-24-2017, 09:06 AM
Windows 10
Geforce GT730
secondary display (PT): Dell ST2421L 1920*1080 (native)
primary display (video window): Optoma HD142x projector 1920*1080 1080p (native)
I used to have 2 monitors on the gt730 for PT and the projector on Blackmagic Intensity Pro, but due to the BM issues I removed it.
It's not too bad as all the info is still on the lcds, it just feels a bit weird.
Thanks for chiming in!
Old 06-24-2017, 09:30 AM
EddieJones's Avatar
Try dragging the S3 out and in again with EuControl running on either monitor. Did you update the firmware ?
Old 06-26-2017, 12:32 AM
None of that seems to do the trick. I also tried setting the Optima to 720p as that was the resolution of the video I was working on. So far no luck. Would it help if I experimented some more with different resolutions on both monitors?
Old 06-26-2017, 04:27 AM
ShiftStudios ShiftStudios is offline
Can confirm this is happening to me also.
Mobo: Gigabyte Z270X-Gaming 7
CPU: i7 7700k - stock speeds
Memory: 16GB Corsair Vengance DDR4 3000
GPU: Gigabyte Aorus 1080Ti Extreme
Primary Monitor: ACER CB280HK
Secondary Monitor: Acer T272HUL
Primary Controller: AVID S3
Secondary Controller: Pro Tools | Dock + Pro Tools | Control
EuCon also reports that Pro Tools | Control is out of date, even though it's been updated.
Was working fine until the 3.6.1 update. Can I roll back?
Do you even QA bro?
Shift Studios
Computer: Custom Built PC
Mobo: Gigabyte Aorus Z270X-Gaming 7
CPU: i7 7700k
MEM: 16GB Corsair Vengance DDR4 3000
GPU: Gigabyte Aorus GTX 1080Ti Extreme
OS: Windows 10 Pro x64
DAWs Pro Tools 12.7.1
Interface: Universal Audio
Preamps: Focusrite, Universal Audio
Outboard Processors: Universal Audio
Control Surfaces: AVID S3, Pro Tools | Control + Pro Tools | Dock
Old 06-26-2017, 05:00 AM
Okay Uninstalled 3.6.1, restarted, Installed 3.6, restarted.
S3 fonts are right size and S3 appears to be working as expected.
Pro Tools | Dock, appears to be working.
Eucon still gives the error message: "Pro Tools | Control and EuControl versions are incompatible" and refuses to let the | Control connect, and I don't believe there is a way to roll back a version in the App store? So if this isn't working, then technically, the Dock is only half working, since | Control is half of the equation.
Any ideas?
Shift Studios
CPU: i7 7700k
Old 06-26-2017, 11:17 AM
EddieJones's Avatar
Unfortunately the App Store can't have 2 versions in it so only 3.6.1 will work. We are working on this right now but can you try something for me in the meantime. Disconnect one of your monitors and then restart EuControl and see if the fonts are OK with just 1 monitor connected. If so whilst still running connect back the second monitor.
Old 06-26-2017, 11:59 AM
EddieJones's Avatar
We've been trying to reproduce this and can't. Have you updated the firmware on the S3 ? What's the build of Windows you are running ?
Old 06-26-2017, 04:19 PM
Hi EddieJones,
Second monitor has nothing to do with it. If it's display based it would be that the EuCon software version 3.6.1 is not handling DPI properly. 3.6 does however.
As stated I am running Windows 10 Anniversary with all updates. If you cannot replicate it, can you remove it from the downloads and roll the app back in the store? I'm a small business owner paying a lease on equipment that I currently cannot use because of your updates. It's disappointing as things have been going so well recently.
I would be happy to look at the code for you if you've not kept an internal change-log and are not sure what changes you made would impact this.
EDIT: Also want to make the note that even with EuCon 3.6.1 installed, and the iPad updated to the latest version of Pro Tools | Control I get the following error: "Pro Tools | Control and EuControl versions are incompatible" So apparently even the latest version of EuCon and Pro Tools | Control are incompatible with eachother? So what version of EuCon am I supposed to use with the latest version (only available version on the App Store) of Pro Tools | Control?
EDIT 2: Also yes, updated all firmware that required an updated (checked every device in EuCon software to make sure).
Shift Studios
CPU: i7 7700k
Eucon 3.2.2 installer error + firmware downwards compatible with eucon 3.1 deauditievedienst Artist Series 2 07-14-2021 09:33 AM
Updated to Eucon 3.6 and lost all my custom Eucon commands bassmagnetic Avid S1, S3, Dock and Control App 0 04-18-2017 10:09 AM
Opening oversized PT12 HD session in non-HD PT12? mjpatey Pro Tools 12 6 01-10-2017 09:25 AM
EuCon suddenly broken - Eucon client can not access the bonjour service noiseboyuk Artist Series 0 04-12-2016 12:34 PM
