192 I/O unbalanced input in a balanced setup
Greetings from an old-newbie!
A quick 192io input related question. In my new brand 192 I/O I have a "+4 dBu Balanced input" scenario (+4 dBu DB-25 outputs connected to a balanced patch bay). For about a week I do need to route an unbalanced signal -10 dB(V) (consumer device) into a pair of 192 balanced inputs. I don't want (and I've no time) to change my setup or something. I'd like to know: is it possible to connect (via balanced patch bay) and record an unbalanced signal into the 192 balanced inputs (I don't matter the +4/-10 signal volume issue)? The "192 IO Guide" states: " You can connect -10 dB(V) signals to the -10 dB(V) inputs, but you will need to make sure that the negative terminals are not connected.", is it something? Any help and advice will be very appreciate. Ale |
Re: 192 I/O unbalanced input in a balanced setup
Gosh, you'd hate to have to do anything!!!
Buy a Matchbox. Every studio should have one anyway. |
You're right, more than 11 years on DUC...
BTW, the Matchbox is a good idea but is there any other suggestion? What is going to happen if I "simply" plug the unbalanced jack into the 192 balanced ones? Are the 192 circuits going to "destroy" themselves? |
no, they won't be destroyed
I don't remember the pinout of the -10dBv inputs but I think you could just move the DB25 to the -10 input connector then back when your done.
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
The pinout diagrams look pretty much the same but the 192 is in a not very accessible 19" rack and sadly I can't remove the interface for now.
Anyway moving the DB25 connector could solve the volume/impedance issue. My concern is the possibility to connect a mono unbalanced signal to a balanced connector (both +4 and -10) with "the negative terminals connected". I mean, could the 192 circuit be damaged in any way by a connection like this one? |
only if there is a massive amount of DC offset on the signal but then you would have bigger problems
Unbalanced/Balanced?????? | kmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-05-2012 05:19 PM |
1/4" Balanced Output Jack to 1/4" unbalanced aux input heaphone amp | edgarbc1 | General Discussion | 4 | 12-13-2010 09:00 PM |
Balanced / Unbalanced | pipesurfa | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-26-2004 01:44 PM |
Balanced or unbalanced cables w triton/002 setup? | Jak | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-12-2004 08:33 AM |
Should switch from unbalanced to balanced mic input? | el biciclista | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-16-2002 09:10 AM |
