Old 07-02-2007, 02:02 PM
Elton Hyland Elton Hyland is offline
Default How do I transpose....
How do I transpose an MP3 file. Can i take the entire song and transpose it up or down a key? I tried this numerous times but am missing something.
I load the audio file and it shows up as a stereo track.
WinXP Pro. 003 Rack, Command 8. Alesis Powered Monitors, Roland XP80 Kbd. Dual core 1.8 w/ 2 Gigs RAM
Old 07-02-2007, 02:18 PM
jre3132 jre3132 is offline
Default Re: How do I transpose....
TCE or serato pitch and time is what you need.
Mac Pro 3.7 Quad Core Intel
Mac OS X 10.13.2
PT Ultimate HDX 2019.10
64GB RAM
HDX I/O 16x16 Analog
HDX I/O 8x8x8
Old 07-02-2007, 02:41 PM
spkguitar's Avatar
You can do it with the stock plugins; either the pitch shift plugin, or the new Time Shift plugin that is installed in all newer versions of Pro Tools (if you find it is not installed for some reason, you can get it for free here).
Or you can opt for more expensive and higher quality solutions like the above mentioned Serato Pitch-n-time.
Pitch Shift plugin:
  • import audio from source (in your case, mp3 file)
  • select the entire region that was imported
  • from the Pro Tools menus, select AudioSuite->Pitch Shift->Pitch Shift
  • On the Pitch shift plugin interface, make sure Time Correction is checked
  • select the proper value for your transposition on the "Coarse" adjustment slider
Time Shift plugin:
  • from the Pro Tools menus, select AudioSuite->Pitch Shift->Time Shift
  • On the Time shift plugin interface, select "Polyphonic" on the mode dropdown (if it isn't preselected)
  • select the proper value for your transposition by typing in the semitone value in the "Transpose" selector at the bottom right of the plugin interface
Those are the basics. Various other settings for each plugin are covered in the DigiRack Plug-ins guide.
Old 07-02-2007, 06:21 PM
Thx I didn't think to look in the TIME SHIFT dialog. I couldn't get the pitch shift to work no matter what I tried.
Old 07-05-2007, 10:32 AM
OK I give. What am I doing wrong? I load a .mp3 file onto a track. I have WAVEFORM selected on the TRACK VIEW SELECTOR. I highlight the entire stereo track with the GRABBER TOOL. It turns black. I select AUDIO SUITE - PITCH SHIFT - TIME SHIFT. Across the top it says TIME SHIFT - PLAYLIST - USE IN PLAYLIST then CREATE CONTINUOUS FILE - ENTIRE SELECTION - MONO MODE. The COMPARE button is selected ( It turns White )
In the PITCH box I select Transpose to -1.00 for example. BYPASS is NOT selected. When I select PREVIEW, I hear the pitch change. When I select PROCESS, it doesn't change anything. The pitch stays at the original pitch. How do I get this to change the pitch of the entire .MP3 file?
thanks
Transpose Chords... andrum Pro Tools 10 20 02-16-2020 07:49 AM
Transpose Chords strangeLoop Pro Tools 9 0 06-07-2011 02:40 PM
transpose Jel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-19-2009 08:44 PM
Best Transpose Plug in for PT? buckaroo Pro Tools TDM Systems (Mac) 16 04-30-2009 07:56 AM
Transpose Audio (WAV, MP3, Etc.) BradyP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-12-2007 07:31 PM
